[Bio] / RecoElemSBW / SBMLtoRecoElem.cc Repository:
Log of /RecoElemSBW/SBMLtoRecoElem.cc
Thu Sep 18 23:24:48 2003 UTC (16 years, 2 months ago) by hwang
CVS Tags: HEAD
Changes since 1.5: +9 -0 lines
	Fixed spelling mistakes. Everything compiles now.
Thu Sep 18 21:18:40 2003 UTC (16 years, 2 months ago) by efrank
Changes since 1.4: +3 -3 lines
Move all of SbmlFactory into SbwFactory and migrate SBMLtoRecoElem to
match.
SBMLtoRecoElem.cc:
   makes an SbwFactory rather than SbmlFactory and then uses it
SbmlFactory.cc, SbmlFactory.hh:
SbwFactory.{cc,hh}
   Now has guts fo SbmlFactory plus skeleton for writeToSbmlFile(char* filename)
Thu May 22 19:25:22 2003 UTC (16 years, 6 months ago) by efrank
Changes since 1.3: +5 -160 lines
put sbml->recoelem into a factory so it can be called, i.e., take it out of main() in the r&d executable
Thu May 8 18:12:11 2003 UTC (16 years, 6 months ago) by efrank
CVS Tags: ldrd-2003-01
Changes since 1.2: +1 -2 lines
Migrate RecoElem to not use RecoElemImpl
Fri Apr 25 23:33:14 2003 UTC (16 years, 6 months ago) by efrank
some fixes with respect to direction and pr9inting
Fri Apr 25 20:26:22 2003 UTC (16 years, 6 months ago) by hwang
Diff to selected 1.3
SBMLtoRecoElem.cc
   an app to read an SBML model into a RecoElem
Makefile
   mods to support above
