[Bio] / RAST / rast.cgi Repository:
Log of /RAST/rast.cgi
Links to rast_rel_2010_1206: (view) (download) (annotate)
Wed Apr 28 21:58:51 2010 UTC (9 years, 7 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, myrast_33, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Diff to previous 1.13 , to selected 1.5
New RAST genome upload support.
Wed Oct 28 20:50:42 2009 UTC (10 years, 1 month ago) by olson
CVS Tags: rast_rel_2010_0118
Changes since 1.12: +1 -3 lines
Diff to previous 1.12 , to selected 1.5
In non-fcgi case, it is okay if eval returns cgi_exit
Wed Aug 26 20:32:04 2009 UTC (10 years, 3 months ago) by olson
CVS Tags: rast_rel_2009_0925
Changes since 1.11: +139 -32 lines
Diff to previous 1.11 , to selected 1.5
Performance optimizations, flip to 'die cgi_exit' instead of'exit'.
Mon Jul 20 14:24:43 2009 UTC (10 years, 4 months ago) by paczian
Changes since 1.10: +1 -0 lines
Diff to previous 1.10 , to selected 1.5
added link to seedviewer to the home menu
Wed Jul 8 20:56:12 2009 UTC (10 years, 5 months ago) by olson
CVS Tags: rast_rel_2009_07_09
Diff to previous 1.9 , to selected 1.5
use web_app_default.css instead of default.css
Mon Apr 6 12:18:00 2009 UTC (10 years, 8 months ago) by paczian
CVS Tags: rast_rel_2009_05_18
Changes since 1.8: +2 -0 lines
Diff to previous 1.8 , to selected 1.5
added menu entries that link to About RAST and RAST FAQ
Thu Nov 20 15:42:20 2008 UTC (11 years ago) by paczian
CVS Tags: rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26
Changes since 1.7: +3 -14 lines
Diff to previous 1.7 , to selected 1.5
adjustments for FIGM usage
Thu Oct 16 22:30:43 2008 UTC (11 years, 1 month ago) by olson
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_rel_2008_10_29
Initial changes to support mod_perl with RAST/SeedViewer:
Template loading requires absolute path. We use TMPL_PATH for this.
add_css used to use TMPL_PATH, but css paths are in URL space, not in
filesystem space. Add new TMPL_URL_PATH to WebConfig and use that instead.
WebApplication::run should not exit; mod_perl doesn't like it and it isn't necessary. Just return.
Mon Aug 18 20:29:32 2008 UTC (11 years, 3 months ago) by dsouza
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_release_2008_09_29
Changes since 1.5: +13 -6 lines
Check if MG-RAST for correct home, etc.
Revision 1.5 - (view) (download) (annotate) - [selected]
Tue Apr 8 20:18:42 2008 UTC (11 years, 8 months ago) by paarmann
CVS Tags: rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07
Changes since 1.4: +14 -1 lines
switches layout based on rast_type setting
Fri Feb 29 21:19:26 2008 UTC (11 years, 9 months ago) by paarmann
added menu item to Control Center
Fri Feb 8 22:22:43 2008 UTC (11 years, 10 months ago) by paarmann
Changes since 1.2: +6 -0 lines
added option for sitemeter FIG config settings
Fri Jan 11 15:50:01 2008 UTC (11 years, 10 months ago) by paarmann
added title prefix
Thu Dec 13 17:04:12 2007 UTC (11 years, 11 months ago) by paarmann
Diff to selected 1.5
