[Bio] / RAST / rast.cgi Repository:
Log of /RAST/rast.cgi
Links to rast_rel_2008_09_29: (view) (download) (annotate)
Mon Aug 18 20:29:32 2008 UTC (11 years, 3 months ago) by dsouza
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_release_2008_09_29
Changes since 1.5: +13 -6 lines
Check if MG-RAST for correct home, etc.
Tue Apr 8 20:18:42 2008 UTC (11 years, 8 months ago) by paarmann
CVS Tags: rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07
Changes since 1.4: +14 -1 lines
switches layout based on rast_type setting
Fri Feb 29 21:19:26 2008 UTC (11 years, 9 months ago) by paarmann
added menu item to Control Center
Fri Feb 8 22:22:43 2008 UTC (11 years, 10 months ago) by paarmann
Changes since 1.2: +6 -0 lines
added option for sitemeter FIG config settings
Fri Jan 11 15:50:01 2008 UTC (11 years, 11 months ago) by paarmann
added title prefix
Thu Dec 13 17:04:12 2007 UTC (12 years ago) by paarmann
