[Bio] / RAST / RASTShared.pm Repository:
Log of /RAST/RASTShared.pm
Thu Dec 18 12:57:38 2008 UTC (11 years, 5 months ago) by paczian
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, myrast_33, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
changed menu category to "Manage Job #x"
Mon Jun 16 16:23:55 2008 UTC (11 years, 11 months ago) by paczian
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_release_2008_09_29
fixed delete job entry in menu
Mon Apr 21 19:37:31 2008 UTC (12 years, 1 month ago) by paczian
CVS Tags: rast_rel_2008_04_23, rast_rel_2008_06_16
added link to GenomeStatistics page for debuggers
Mon Apr 14 19:38:34 2008 UTC (12 years, 1 month ago) by paarmann
method get_menu_job for the shared menu
