[Bio] / RAST / Makefile Repository:
Log of /RAST/Makefile
Links to rast_rel_2014_0729: (view) (download) (annotate)
Wed Apr 28 21:58:51 2010 UTC (9 years, 11 months ago) by olson
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, myrast_33, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.9: +1 -0 lines
New RAST genome upload support.
Fri Jan 9 14:10:18 2009 UTC (11 years, 3 months ago) by olson
CVS Tags: rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118
Changes since 1.8: +2 -2 lines
Remove -p from cp commands.
Mon Dec 22 23:33:47 2008 UTC (11 years, 3 months ago) by olson
Changes since 1.7: +10 -1 lines
Add support for suexec - if CGI directory contains "public_html", ensure that any
installed CGI scripts and the CGI directory itself are not group or world writable.
Fri Jun 13 19:18:43 2008 UTC (11 years, 9 months ago) by wilke
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Changes since 1.6: +2 -1 lines
added OntologyOnDemand
Mon Mar 24 20:24:15 2008 UTC (12 years ago) by paczian
Changes since 1.5: +0 -2 lines
removed rights thing
Thu Feb 14 22:21:22 2008 UTC (12 years, 1 month ago) by paarmann
added .tmpl file in templates dir
Sun Dec 16 10:07:09 2007 UTC (12 years, 3 months ago) by paarmann
Sun Dec 16 10:05:57 2007 UTC (12 years, 3 months ago) by paarmann
Changes since 1.2: +10 -6 lines
Revision 1.2 - (view) (download) (annotate) - [selected]
Fri Dec 14 15:48:55 2007 UTC (12 years, 3 months ago) by paarmann
Fri Nov 2 16:19:59 2007 UTC (12 years, 5 months ago) by paarmann
Diff to selected 1.2
