[Bio] / PyGUI / pluginExample.py Repository:
Log of /PyGUI/pluginExample.py
Wed Jul 14 20:45:24 2004 UTC (15 years, 4 months ago) by efrank
CVS Tags: HEAD, MigrateToNewPackage, V00-00-03, forRick-14Jul04-1, mass-spec-01, mass-spec-02, mass-spec-03
Changes since 1.1: +38 -27 lines
migrate to new plugin interface.
fix onLeftClick for SetLabel -> setValue
Wed Jun 9 22:36:10 2004 UTC (15 years, 5 months ago) by efrank
CVS Tags: V00-00-02, forKubal-15Jun04, forRick-14Jul04-0, larrys-08jul04
o clean up double foundryId problem in FoundryItems
o change names in CatalogEntry to read() and write()
o write the write() method just mentioned
o get writing to work again, propagate changes into PyGUI
o add plugin capability to modelEditor
