[Bio] / PyGUI / RXFromMetPageDialog.py Repository:
Log of /PyGUI/RXFromMetPageDialog.py
Fri Jul 2 22:08:02 2004 UTC (15 years, 3 months ago) by hwang
CVS Tags: HEAD, MigrateToNewPackage, V00-00-03, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, mass-spec-03
Changes since 1.12: +35 -36 lines
	To maintain state, self was taken out of local variables
Thu May 20 20:46:26 2004 UTC (15 years, 4 months ago) by hwang
CVS Tags: V00-00-02, forKubal-15Jun04, larrys-08jul04
RXOnAddPageDialog.py and RXpanel
	added functions to allow the user to get the Enzyme grid to be selected
in the RXAddPageDialog
        made some minor chances
Wed Feb 25 17:08:17 2004 UTC (15 years, 7 months ago) by hwang
     Changed all the files so that the past inconsistancies of variable and classes names
 are consistant. I.E. MainLayout import MainLayout.
     In MainLayout, separate functions are made for each panel.
Mon Feb 9 19:33:31 2004 UTC (15 years, 8 months ago) by efrank
correct all of the imports to standard form of from foo.bar import bar.
weren't using package name, foo in many cases
Wed Nov 12 22:56:33 2003 UTC (15 years, 11 months ago) by efrank
CVS Tags: SC-01, SC-02, sc-12Nov03-linux-02, sc-14Nov03-linux-01, sc-14Nov03-linux-02
Changes since 1.8: +49 -40 lines
Lots of changes to start port to mac.  lots of fiddling with layout because
we are doing something wrong, and it shows up on Mac.
Also alot of work to make enzymes work, including EC.  focus is on seed.
Mon Aug 18 16:11:02 2003 UTC (16 years, 2 months ago) by hwang
CVS Tags: V00-00-01, efrank-initialSeed-04Nov03, sc-06Nov03-linuxLeft-01, sc-12Nov03-linux-01, sc-works-00
Changes since 1.7: +6 -3 lines
	-MainLayou.py & RXFromMetPageDialog.py
	   combobox is readonly
	-RXpanel.py
	   grid info is scrollable
	-RecoElempanel.py
	   in the process of getting pt position to line up with popup menu
Mon Aug 18 15:55:57 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: V00-00-00
Changes since 1.6: +6 -0 lines
Start documenting the code a trifle.  All files have been modified by adding
the list of def'd methods at the top of the class.  Must add description
strings, but this is a start.
Sat Aug 16 20:51:50 2003 UTC (16 years, 2 months ago) by efrank
Changes since 1.5: +15 -13 lines
Lots of changes here and there to get reaction searching working.
start to work on right-click-in reaction list_box (recoelem page).
Sat Aug 16 04:28:08 2003 UTC (16 years, 2 months ago) by efrank
Changes since 1.4: +52 -13 lines
Get Rx searching working.  Requires HEAD of FaST.
Still has bugs but basically runs.
Fri Aug 15 21:47:58 2003 UTC (16 years, 2 months ago) by hwang
Changes since 1.3: +15 -17 lines
	  added Destroy to kill modals
Fri Aug 15 20:41:25 2003 UTC (16 years, 2 months ago) by hwang
Changes since 1.2: +27 -1 lines
	MetabolitePanel.py
	   Add clear to the bottom selected grid
	   The checkboxes implemented
	RXpanel.py
	   In the process of wiring in searching. not done yet
Thu Aug 14 22:52:50 2003 UTC (16 years, 2 months ago) by hwang
Changes since 1.1: +8 -4 lines
	MainLayout.py
	   Added Enzyme page
	MetabolitePanel.py
	   grid.ClearGrid() added
	   fixed some layout properties
	RXpanel.py
	   text is Enable(False) when FromMetabolitePage is picked
Thu Aug 14 20:42:25 2003 UTC (16 years, 2 months ago) by hwang
	MainLayout.py
	   Added changes to rxWindow
	MetabolitePanel.py
	   Links up with DoubleTextEntryDialog.py
	   Add new metabolites
	RXpanel.py
	   If ComboBox is "FromMetPageDialog", pops up a grid and put in the appropriate info
		from MetPageDialog bottom grid
	   Layout of search grid for FromMetPageDialog
