[Bio] / PyGUI / README Repository:
View of /PyGUI/README
Revision 1.1 - (download) (annotate)
Wed Nov 12 22:56:33 2003 UTC (16 years ago) by efrank
CVS Tags: V00-00-03, V00-00-02, MigrateToNewPackage, sc-14Nov03-linux-02, mass-spec-01, forRick-14Jul04-0, mass-spec-03, mass-spec-02, sc-12Nov03-linux-02, forRick-14Jul04-1, sc-14Nov03-linux-01, forKubal-15Jun04, larrys-08jul04, SC-02, SC-01, HEAD
Lots of changes to start port to mac.  lots of fiddling with layout because
we are doing something wrong, and it shows up on Mac.
Also alot of work to make enzymes work, including EC.  focus is on seed.
This code is in shambles at the moment.  It is at the end of a first prototyping stage
where we were learning python and learning wxPython.  Also, we were identifying places
for generalization.  For example, we knew that DataFactories were going to be
instances of a base class, but did not know what set of functions to have because
we don't know the variation over the data sources yet.  Sure, we can posit some
function-set, but we deciced to just connect to some and play.
What that means for the code is that there are long, long hunks of code that look
like, "check dataSource selector, based on the value, figoure out which of our
functions to call, then that function does factory-specific stuff."
This can all be replaced with a single fetch of the factory and execution of
base-methods...once the base class is in place.
Each new one we've added has broken our expectations so far.
Real Soon Now....
