[Bio] / PyGUI / ModelEditor.py Repository:
Log of /PyGUI/ModelEditor.py
Fri Sep 10 13:32:59 2004 UTC (15 years, 2 months ago) by efrank
CVS Tags: HEAD, MigrateToNewPackage
migrate to standard.mk makefile format.
rename to satisfy that.
