[Bio] / PyGUI / Makefile Repository:
Log of /PyGUI/Makefile
Fri Sep 10 13:32:59 2004 UTC (15 years, 1 month ago) by efrank
CVS Tags: HEAD, MigrateToNewPackage
Changes since 1.2: +11 -22 lines
migrate to standard.mk makefile format.
rename to satisfy that.
Mon Feb 9 19:33:31 2004 UTC (15 years, 8 months ago) by efrank
CVS Tags: V00-00-02, V00-00-03, forKubal-15Jun04, forRick-14Jul04-0, forRick-14Jul04-1, larrys-08jul04, mass-spec-01, mass-spec-02, mass-spec-03
correct all of the imports to standard form of from foo.bar import bar.
weren't using package name, foo in many cases
Mon Feb 9 19:13:30 2004 UTC (15 years, 8 months ago) by efrank
Makefile:
	needed one
main.py, ModelEditor:
	rename
