[Bio] / PyGUI / MainMenuBar.py Repository:
Log of /PyGUI/MainMenuBar.py
Wed Jul 14 20:22:13 2004 UTC (15 years, 4 months ago) by efrank
CVS Tags: HEAD, MigrateToNewPackage, V00-00-03, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, mass-spec-03
Diff to previous 1.17
getting it to work.  in a rush for rick demo.
Wed Jul 14 16:33:26 2004 UTC (15 years, 4 months ago) by hwang
Changes since 1.16: +4 -3 lines
Diff to previous 1.16
	Add changes to dialog size
Wed Jul 14 16:29:11 2004 UTC (15 years, 4 months ago) by efrank
Changes since 1.15: +9 -8 lines
rearrange items.  change caps.
Tue Jul 13 21:15:07 2004 UTC (15 years, 4 months ago) by efrank
Changes since 1.14: +4 -13 lines
Schema:
	o change size of Function column from 64 to 128.
	  More reasonable size and avoids a crash.
	o RebuldDb...runs all the steps of rebuilding the database.
	o biuldNewBssCatalog:  go to new BssFactory ctor
CatalogServices:
	o remove setFoundryId from DataFactoryBase.  Now expect that info
	  to be in the DB itself and for ctor of derivative to set it.
FaST:
	o Migrate to new DbManager from DBconnect.  Includes moving to
	  new nextSeqVal().
	o Now get fid from database
PyGui:
	o Changed to follow mods above.
	o
Mon Jul 12 20:38:19 2004 UTC (15 years, 4 months ago) by efrank
Changes since 1.13: +65 -4 lines
KahOM/KahDataMgr:
	first pass at top level data manager to be returned from catalogentry read
Schema:
	added KahDatabaseInfo to put fid into database.
	create- changed so that no long initialize name of top catalogEntry (see below)
	destroyBss- changed !#/usr/bin/py to env py
FaST:
	txMgr - fixed close()...added self
	BssFactory - now gets fid via kahDatabaseInfo in database
PyGUI
	change so that something or another
Mon Jul 12 17:12:43 2004 UTC (15 years, 4 months ago) by ctreatma
Changes since 1.12: +27 -32 lines
Use 2-element dialog to get host/port.
Remove some test code.
Fri Jul 9 20:02:49 2004 UTC (15 years, 4 months ago) by ctreatma
Changes since 1.11: +19 -13 lines
	Fixed issues with AGGetPubDialog.
Fri Jul 9 15:29:36 2004 UTC (15 years, 4 months ago) by sheradon
Changes since 1.10: +42 -16 lines
Catalogpanel.py
	change catalog load so that a) turn off localhost seed b) stuff
 i don't remember
MainLayout:
	in callback for newDataFactory in catalog:  remember to get catalog
	loaded
MainMenuBar:
Thu Jul 8 14:56:17 2004 UTC (15 years, 4 months ago) by ctreatma
Changes since 1.9: +12 -21 lines
	Removed test code from MainMenuBar.py, implemented popup dialog for connecting to servers published on the AG. (Charles)
Thu Jul 8 01:47:39 2004 UTC (15 years, 4 months ago) by efrank
Changes since 1.8: +5 -2 lines
Redid the pluggin stuff. Now a module that is loaded is expected to have
a function called registerHook.  It takes an argument that is a functin.
You call that function to register INSTANCES of a derivative of KahModule
along with a menu entry name and a help string.
Also, reworked so that we load configuration information and shove it into
the module.
Tue Jul 6 21:11:48 2004 UTC (15 years, 4 months ago) by hwang
Changes since 1.7: +37 -2 lines
	DoubleTextEntryDialog
		Made changes to appearance of the Dialog
	MainLayout
		still in the process of fixing the combobox
	MainMenuBar
		add server/proxy dialog and connect to BssFactoryProxy
Tue Jul 6 19:58:57 2004 UTC (15 years, 4 months ago) by hwang
	fixed typo in MainMenuBar
Tue Jul 6 19:53:10 2004 UTC (15 years, 4 months ago) by hwang
Changes since 1.5: +16 -6 lines
	MainMenuBar
	  put in the AGGetPubDialog for Charles
	AGGetPubDialog
	  grid information popup
Fri Jul 2 22:16:11 2004 UTC (15 years, 4 months ago) by efrank
Changes since 1.4: +3 -1 lines
CatalogEntry:
	fix RecoElem ctor
DBConnect:
	remove print
RecoElem:
	add apply() method to apply func recurseively
MainMenuBar:
	resolv conflict that wa trivial space
Fri Jul 2 20:11:49 2004 UTC (15 years, 4 months ago) by efrank
Changes since 1.3: +11 -7 lines
these are charles' changes...committing for him while he's away.
DataFactoryBase:
	add setFoundryId()
BssFactoryServer:
	work on arg lists processing
MainMenuBar:
	access to AG related operations
KahCatAGCfgMgr:
	manages data sharing via AG
Wed Jun 30 18:08:48 2004 UTC (15 years, 4 months ago) by ctreatma
Changes since 1.2: +124 -6 lines
     Update based on changes to KahCatAGCfgMgr--change publish to advertise, change snarf to doAGgetPub.-
Wed Jun 9 22:36:10 2004 UTC (15 years, 5 months ago) by efrank
CVS Tags: V00-00-02, forKubal-15Jun04, larrys-08jul04
Changes since 1.1: +20 -1 lines
o clean up double foundryId problem in FoundryItems
o change names in CatalogEntry to read() and write()
o write the write() method just mentioned
o get writing to work again, propagate changes into PyGUI
o add plugin capability to modelEditor
Wed May 26 01:38:25 2004 UTC (15 years, 6 months ago) by efrank
Lots of work aimed at getting catalog services to work, incorporating
catalog editing into the model editor, and simplifying the api
for going form path to model in hand to work with.
CatalogEntryTop was changed to CatalogEntrBase and made base of CatalogEntry
rather than other way around to break a dependency loop that was causing
python import problems.  CatalogEntry is still the base class to use
for extending to new data factories.
changed open() to return catalogEntry rather than foundryItemKey.  simpler
for the user and more opportunity to encapsulate.
made catalogEntry able to read a recoElem and return it.  all done in
terms of arch abstractions.  this is temorary.  we will add a Navigator
or Manager class and that will be returned from the CatalogEntry rather
than recoElem.  that's becausee Recoelem is just one of many things
that will be present, e.g., conditions data.
PyGui/MainMenuBar.  split out to help stay sane for when that becomes
more complex.
Moved add seed server to menu bar so that right click in catalog panel
coudl be used to pull up catalog editing tools.
