[Bio] / PyGUI / HelpPanel.py Repository:
Log of /PyGUI/HelpPanel.py
Wed Jun 9 22:36:10 2004 UTC (15 years, 6 months ago) by efrank
CVS Tags: HEAD, MigrateToNewPackage, V00-00-02, V00-00-03, forKubal-15Jun04, forRick-14Jul04-0, forRick-14Jul04-1, larrys-08jul04, mass-spec-01, mass-spec-02, mass-spec-03
o clean up double foundryId problem in FoundryItems
o change names in CatalogEntry to read() and write()
o write the write() method just mentioned
o get writing to work again, propagate changes into PyGUI
o add plugin capability to modelEditor
Tue Aug 19 17:37:36 2003 UTC (16 years, 3 months ago) by hwang
CVS Tags: SC-01, SC-02, efrank-initialSeed-04Nov03, sc-06Nov03-linuxLeft-01, sc-12Nov03-linux-01, sc-12Nov03-linux-02, sc-14Nov03-linux-01, sc-14Nov03-linux-02, sc-works-00
	MainLayout.py
	    Added HelpPanel
	RecoElempanel.py
	    Update text of tree. not yet tested
	main.py
	    Calls the HelpPanel
	HelpPanel.py
	    Loads ModelEditor.html
