[Bio] / PyGUI / HelpPanel.py Repository:
Log of /PyGUI/HelpPanel.py
Links to sc-06Nov03-linuxLeft-01: (view) (download) (as text) (annotate)
Tue Aug 19 17:37:36 2003 UTC (16 years, 3 months ago) by hwang
CVS Tags: SC-01, SC-02, efrank-initialSeed-04Nov03, sc-06Nov03-linuxLeft-01, sc-12Nov03-linux-01, sc-12Nov03-linux-02, sc-14Nov03-linux-01, sc-14Nov03-linux-02, sc-works-00
	MainLayout.py
	    Added HelpPanel
	RecoElempanel.py
	    Update text of tree. not yet tested
	main.py
	    Calls the HelpPanel
	HelpPanel.py
	    Loads ModelEditor.html
