[Bio] / PyGUI / FontManager.py Repository:
Log of /PyGUI/FontManager.py
Links to mass-spec-03: (view) (download) (as text) (annotate)
Fri Mar 5 19:30:38 2004 UTC (15 years, 8 months ago) by hwang
CVS Tags: HEAD, MigrateToNewPackage, V00-00-02, V00-00-03, forKubal-15Jun04, forRick-14Jul04-0, forRick-14Jul04-1, larrys-08jul04, mass-spec-01, mass-spec-02, mass-spec-03
	Catalogpanel.py
		Got rid of the "Load to Navigator" button
	FontManager.py
		fixed variable consistancy
	MainLayout.py
		Added combobox label and got rid of "Load to Navigator" button
Wed Feb 25 17:08:17 2004 UTC (15 years, 8 months ago) by hwang
Changes since 1.2: +3 -2 lines
     Changed all the files so that the past inconsistancies of variable and classes names
 are consistant. I.E. MainLayout import MainLayout.
     In MainLayout, separate functions are made for each panel.
Mon Feb 9 19:33:31 2004 UTC (15 years, 9 months ago) by efrank
correct all of the imports to standard form of from foo.bar import bar.
weren't using package name, foo in many cases
Fri Dec 19 22:56:33 2003 UTC (15 years, 10 months ago) by hwang
	MainLayout.py
	   added changes to sizers for a few labels. When font is change there will be no overlapping
	main.py
	   added selectFont
	FontManager.py
	   will eventually have a list of labels, trees, grids labels that will be updated
	current problem:
	    catalog_tree has a strange refresh problem
