[Bio] / PyGUI / EnzymeWindow.py Repository:
Log of /PyGUI/EnzymeWindow.py
Wed Jul 14 20:22:13 2004 UTC (15 years, 4 months ago) by efrank
CVS Tags: HEAD, MigrateToNewPackage, V00-00-03, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, mass-spec-03
Changes since 1.12: +0 -1 lines
getting it to work.  in a rush for rick demo.
Mon Jul 12 20:38:19 2004 UTC (15 years, 4 months ago) by efrank
Changes since 1.11: +0 -98 lines
KahOM/KahDataMgr:
	first pass at top level data manager to be returned from catalogentry read
Schema:
	added KahDatabaseInfo to put fid into database.
	create- changed so that no long initialize name of top catalogEntry (see below)
	destroyBss- changed !#/usr/bin/py to env py
FaST:
	txMgr - fixed close()...added self
	BssFactory - now gets fid via kahDatabaseInfo in database
PyGUI
	change so that something or another
Wed Jun 23 19:19:10 2004 UTC (15 years, 4 months ago) by efrank
CVS Tags: larrys-08jul04
migrate import statements to follow move of Recoelem, Reaction, Reactant
from FaST to KahOM
Wed Jun 23 19:02:51 2004 UTC (15 years, 4 months ago) by efrank
Changes since 1.9: +43 -10 lines
Migrate data classes to really use FoundryItem.
gut a bunch of old dead code.
merge what used to be separate seed/bss into single.
Wed May 26 01:38:25 2004 UTC (15 years, 5 months ago) by efrank
CVS Tags: V00-00-02, forKubal-15Jun04
Changes since 1.8: +7 -5 lines
Lots of work aimed at getting catalog services to work, incorporating
catalog editing into the model editor, and simplifying the api
for going form path to model in hand to work with.
CatalogEntryTop was changed to CatalogEntrBase and made base of CatalogEntry
rather than other way around to break a dependency loop that was causing
python import problems.  CatalogEntry is still the base class to use
for extending to new data factories.
changed open() to return catalogEntry rather than foundryItemKey.  simpler
for the user and more opportunity to encapsulate.
made catalogEntry able to read a recoElem and return it.  all done in
terms of arch abstractions.  this is temorary.  we will add a Navigator
or Manager class and that will be returned from the CatalogEntry rather
than recoElem.  that's becausee Recoelem is just one of many things
that will be present, e.g., conditions data.
PyGui/MainMenuBar.  split out to help stay sane for when that becomes
more complex.
Moved add seed server to menu bar so that right click in catalog panel
coudl be used to pull up catalog editing tools.
Fri Mar 26 17:12:46 2004 UTC (15 years, 7 months ago) by efrank
Changes since 1.7: +9 -20 lines
Modifications to install the new Catalog code, FoundryId stuff.  I ripped
out old code as well:  the list of foundryComboBoxes is gone since we now
have just one combo box.
the notion of FoundryId's intVal is gone.  at least for the moment.  it's too hard
at the mment to have a (bottleneck!) central authority to manage the intVals.
so, starting now, foundryId's are based on strings that are notionally URLs and
its up to the dataFoundry manager to make sure all distinct instances at his
site have distinct urls.
this also means that if a foundry moves, then the history information that
refers to it becomes incorrect.
Thu Mar 25 00:49:56 2004 UTC (15 years, 7 months ago) by efrank
Migrating to new Catalog, Catlogentry, etc.  This is an intermediary
sync
Fri Mar 19 20:43:12 2004 UTC (15 years, 8 months ago) by hwang
Changes since 1.5: +4 -4 lines
        Fixed the individual panels to link up with foundryComboBox
Fri Feb 27 21:49:35 2004 UTC (15 years, 8 months ago) by hwang
Changes since 1.4: +6 -3 lines
-       Got rid of the comboboxes for each individual pages and put it on top.
Wed Feb 25 17:08:17 2004 UTC (15 years, 8 months ago) by hwang
     Changed all the files so that the past inconsistancies of variable and classes names
 are consistant. I.E. MainLayout import MainLayout.
     In MainLayout, separate functions are made for each panel.
Mon Feb 9 19:33:31 2004 UTC (15 years, 9 months ago) by efrank
correct all of the imports to standard form of from foo.bar import bar.
weren't using package name, foo in many cases
Wed Nov 12 22:56:33 2003 UTC (16 years ago) by efrank
CVS Tags: SC-01, SC-02, sc-12Nov03-linux-02, sc-14Nov03-linux-01, sc-14Nov03-linux-02
Changes since 1.1: +69 -106 lines
Lots of changes to start port to mac.  lots of fiddling with layout because
we are doing something wrong, and it shows up on Mac.
Also alot of work to make enzymes work, including EC.  focus is on seed.
Wed Nov 5 02:28:44 2003 UTC (16 years ago) by efrank
CVS Tags: efrank-initialSeed-04Nov03, sc-06Nov03-linuxLeft-01, sc-12Nov03-linux-01, sc-works-00
Modifications to read data from Seed.  Now can read all the reactions/compounds
data associatd with a reconstrruction.  In ross' terms, we're reading out
the formal rconstruction.
