[Bio] / PyGUI / DoubleTextEntryDialog.py Repository:
Log of /PyGUI/DoubleTextEntryDialog.py
Wed Jul 14 16:33:26 2004 UTC (15 years, 3 months ago) by hwang
CVS Tags: HEAD, MigrateToNewPackage, V00-00-03, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, mass-spec-03
Changes since 1.3: +6 -7 lines
	Add changes to dialog size
Tue Jul 6 21:11:48 2004 UTC (15 years, 3 months ago) by hwang
Changes since 1.2: +7 -5 lines
		Made changes to appearance of the Dialog
	MainLayout
		still in the process of fixing the combobox
	MainMenuBar
		add server/proxy dialog and connect to BssFactoryProxy
Mon Aug 18 15:55:57 2003 UTC (16 years, 1 month ago) by efrank
CVS Tags: SC-01, SC-02, V00-00-00, V00-00-01, V00-00-02, efrank-initialSeed-04Nov03, forKubal-15Jun04, larrys-08jul04, sc-06Nov03-linuxLeft-01, sc-12Nov03-linux-01, sc-12Nov03-linux-02, sc-14Nov03-linux-01, sc-14Nov03-linux-02, sc-works-00
Start documenting the code a trifle.  All files have been modified by adding
the list of def'd methods at the top of the class.  Must add description
strings, but this is a start.
Thu Aug 14 20:42:25 2003 UTC (16 years, 2 months ago) by hwang
	MainLayout.py
	   Added changes to rxWindow
	MetabolitePanel.py
	   Links up with DoubleTextEntryDialog.py
	   Add new metabolites
	RXpanel.py
	   If ComboBox is "FromMetPageDialog", pops up a grid and put in the appropriate info
		from MetPageDialog bottom grid
	RXFromMetPageDialog.py
	   Layout of search grid for FromMetPageDialog
