[Bio] / PyGUI / Catalogpanel.py Repository:
View of /PyGUI/Catalogpanel.py
Revision 1.37 - (download) (as text) (annotate)
Fri Aug 13 17:41:10 2004 UTC (15 years, 5 months ago) by efrank
CVS Tags: V00-00-03, MigrateToNewPackage, mass-spec-01, mass-spec-03, mass-spec-02, HEAD
Changes since 1.36: +2 -7 lines
Adding a bu
from wxPython.wx             import *
from KahOM.RecoElem           import RecoElem
from PyGUI.RecoElempanel           import RecoElempanel
from CatalogServices.Catalog import Catalog
class Catalogpanel:
    def __init__(self, parent):
        self.parent            = parent
        self.selected = None       #remember last selected catalog entry
                                   #..is used when LOAD button is hit.
        # seedItemId is the wxPython id for the "Seed" node
        # in the catalog tree under which all specific Seed servers
        # are listed
        self.seedItemId        = None
        self.initCatEvents()
        self.initCatData()
        # setup catalog editing menu (right click)
        self.catEditMenu         = wxMenu()
        self.catEditMkItemId     = wxNewId()
        self.catEditMkDirId      = wxNewId()
        self.setupCatEditMenu()
        return
    def initCatEvents(self):
        EVT_TREE_SEL_CHANGED(self.parent.catalog_tree,
                             self.parent.catalog_treeId,
                             self.onLeftClick)
        # Right click on List item for Seed will let you connect to
        # another Seed server
        EVT_RIGHT_DOWN(self.parent.catalog_tree, self.onRightClickCatalogTree)
        EVT_LEFT_DCLICK (self.parent.catalog_tree, self.onLeftDClick)
        EVT_COMBOBOX(self.parent.catVersionValueComboBox,
                     self.parent.catVersionValueComboBox.GetId(),
                     self.onCatVersionValueComboBox)
        return
    def initCatData( self ):
        self.parent.catalogRootId = self.parent.catalog_tree.AddRoot("/")
        self.loadCatalog()
        self.parent.catalog_tree.Expand( self.parent.catalogRootId)
        return
    def setupCatEditMenu(self):
        self.catEditMenu.Append( self.catEditMkDirId,
                                 "New Directory", "NewDirectory" )
        EVT_MENU(self.parent, self.catEditMkDirId, self.doCatEditMkDir)
        self.catEditMenu.Append( self.catEditMkItemId,
                                 "New Item", "NewDirectory" )
        EVT_MENU(self.parent, self.catEditMkItemId, self.doCatEditMkItem)
        return
    def loadCatalog(self):
        wxBeginBusyCursor()
        #localSeedServer        = "http://localhost/FIG"
        #seedFactory   = SeedDataFactory( localSeedServer )
        # DO NOT CREATE BssFactory() HERE ANY LONGER
        # See main progam, ModelEditor
        # Handle top/root of catalog/tree specially to avoid "two root"
        # on display problem
        top = Catalog.instance().getCatalogTop()
        parentTree = self.parent.catalog_tree
        parentTree.SetPyData( self.parent.catalogRootId,
                              (self.recoElemLoader, top, self.parent.catalogRootId) )
        for e in top.entries():
            self.recurseCatalog( e, parentTree, self.parent.catalogRootId)
        parentTree.SortChildren( self.parent.catalogRootId)
        wxEndBusyCursor()
        return
    def recurseCatalog( self, catEntry, parentTree, parentItemId):
        Create a new item under parentItemId in wxTree, parentTree.  Associate
        catEntry with it.  If catEntry has entries, recurse on them.
        if ( catEntry.isTerminal() ):
            displayedName = catEntry.name()
        else:
            displayedName = catEntry.name() + "/"
        newItemId=parentTree.AppendItem(parentItemId, displayedName )
        # associate data needed to manipulate the catEntry
        parentTree.SetPyData( newItemId,
                              (self.recoElemLoader, catEntry, newItemId ) )
        if ( not catEntry.isTerminal() ):
            for e in catEntry.entries():
                self.recurseCatalog( e, parentTree, newItemId)
        parentTree.SortChildren( newItemId )
        return
    def DOOMloadSeedCatalog(self, seedServer ):
        This adds a Seed instance to the catalog.  It is called from the
        MainMenuBar when Data->Add Seed Instance is called, for example.
        wxBeginBusyCursor()
	# The SeedDataFactory ctor is slow and actually reads a bunch of
	# data from the server
        seedFactory   = SeedDataFactory( seedServer )
        # add it to the list in the catalog
        try:
            Catalog.instance().addDataFactory( seedFactory )
        except:
            self.parent.error("loadSeedCatalog: %s already in foundry list." % seedServer)
            wxEndBusyCursor()
            return
        top = seedFactory.getCatalogTop()
        self.recurseCatalog( top, self.parent.catalog_tree, self.parent.catalogRootId)
        wxEndBusyCursor()
        return
    def onLeftClick(self,treeEvent):
        item = treeEvent.GetItem()
        catEntryTuple = self.parent.tree_ctr.GetPyData(item)
        if (catEntryTuple == None ):
            return
        self.selected = catEntryTuple
        catEntry   = catEntryTuple[1]
        # update the history information display
        theBox = self.parent.catVersionValueComboBox
        theBox.Clear()
            self.parent.catPathValue.SetValue( catEntry.path() + "/" )
            self.parent.catVersionValueComboBox.SetLabel( "")
            self.parent.catHistoryDateValue.SetLabel( "" )
            self.parent.catHistoryUserValue.SetLabel( "" )
            self.parent.catHistoryCreatedFromValue.SetLabel( "")
            theBox.SetValue( "" )
        else:
            versions   = catEntry.versions()
            if ( [] == versions ):
                self.parent.catPathValue.SetValue( catEntry.path()+";[None]" )
                theBox.SetValue( "None" )
            else:
                maxVersion = max( versions )
                for v in versions:
                    theBox.Append( "%s" % (v ) )
                    theBox.SetValue( "%s" % (maxVersion) )
                self.parent.catPathValue.SetValue(catEntry.path()+";[%s]" % (maxVersion))
            self.parent.catHistoryDateValue.SetLabel( "no date info yet" )
            self.parent.catHistoryUserValue.SetLabel( "no user info yet" )
            self.parent.catHistoryCreatedFromValue.SetLabel( "no history info yet" )
        return
    def onCatVersionValueComboBox(self, event):
        Handles activity in combo box where user sets Verion to use
        # get the value selected in the combo box.
        choice = event.GetString()
        self.parent.catVersionValueComboBox.SetValue( "%s" % (choice) )
        # the operation is interpreted relative to the currently selected
        # catalogEntry.  find what that is.
        catEntry   = self.selected[1]
        # update stuff
        #version = self.parent.catVersionValueComboBox.GetValue()
        self.parent.catPathValue.SetLabel( catEntry.path()+";[%s]" % (choice) )
        return
    def onRightClickCatalogTree(self, event):
        """ Fires off the pop-up menu to handle right click events. """
        event.GetEventObject().PopupMenu(self.catEditMenu, event.GetPosition())
        return
    def doCatEditMkDir( self, event ):
        if (None == self.selected):
            self.parent.error( "A selection is required first.")
            return
        catEntryTuple = self.selected
        treeItemId    = catEntryTuple[2]
        if (catEntry.isTerminal()):
            self.parent.error("Directories can not be added to items.")
            return
        prompt = "New catalog directory name:"
        dlg = wxTextEntryDialog(self.parent, message=prompt, style=wxOK)
        if ( dlg.ShowModal() == wxID_OK):
            theName = dlg.GetValue()
            if ( theName=="" ): return
            dlg.Destroy()
        else:
            #didn't get a kid name
            dlg.Destroy()
            return
        #try:
        if (1):
            newCatEntry=catEntry.mkDir( theName )
            parentTree=self.parent.catalog_tree
            newItemId=parentTree.AppendItem(treeItemId, newCatEntry.name() )
                                  (self.recoElemLoader, newCatEntry, newItemId )  )
            parentTree.SortChildren( treeItemId )
        else:
        #except:
            self.parent.error( "Operation refused." )
        return
    def doCatEditMkItem( self, event ):
            return
            self.parent.error("Items can not be added to items. Add to a directory.")
            return
        prompt = "New catalog entry name:"
            dlg.Destroy()
        else:
            dlg.Destroy()
            return
        try:
            newCatEntry = catEntry.mkItem( theName )
        except:
        return
    def onLeftDClick(self, event):
        """ Double left-click means, "Load the currently selected item." """
        if ( self.selected == None ):
            self.parent.error( "You must select a catalog entry before requesting load.")
            return
        # We store a loader to actually load the selected item.  This dates
        # back to a time before a single loader could handle all the various
        # data factory kinds.
        apply( catEntryTuple[0], [catEntryTuple[1]] )
        return
    def recoElemLoader(self,  argList ):
        wxBeginBusyCursor()
        (catalogEntry) = argList
        if (catalogEntry.isTerminal() ):
            ver = self.parent.catVersionValueComboBox.GetValue()
            if ( ver == "None" ):
                top = RecoElem( catalogEntry.name() )
            else:
                top = catalogEntry.read( int( ver ) )
            self.parent.re.addRecoElemTree(self.parent.rootId, top, catalogEntry)
        else:
            # current selection is directory. can't load that!
            wxEndBusyCursor()
            return
        wxEndBusyCursor()
        return
