[Bio] / PyGUI / Catalogpanel.py Repository:
Log of /PyGUI/Catalogpanel.py
Links to sc-12Nov03-linux-01: (view) (download) (as text) (annotate)
Wed Nov 5 21:30:08 2003 UTC (16 years, 1 month ago) by efrank
CVS Tags: sc-06Nov03-linuxLeft-01, sc-12Nov03-linux-01
Changes since 1.14: +1 -0 lines
cursor busy was not being turned off in one case
Wed Nov 5 21:07:55 2003 UTC (16 years, 1 month ago) by efrank
Changes since 1.13: +89 -15 lines
Catalogpanel:
	Extend so that multiple Seed servers can be used.  A right click in the
	panel brings up a menu in which there is an "Add Server" entry.  Selecting
	that prompts for a server name.  that server is connected to, the org
	list is read, ettc., and all are put into the catalog.
Wed Nov 5 02:28:44 2003 UTC (16 years, 1 month ago) by efrank
CVS Tags: efrank-initialSeed-04Nov03, sc-works-00
Changes since 1.12: +17 -12 lines
Modifications to read data from Seed.  Now can read all the reactions/compounds
data associatd with a reconstrruction.  In ross' terms, we're reading out
the formal rconstruction.
Fri Oct 17 20:25:57 2003 UTC (16 years, 1 month ago) by efrank
Changes since 1.11: +43 -0 lines
Add catalog for reading from FIG/Seed
Requires updated FaST/
Thu Sep 25 23:48:06 2003 UTC (16 years, 2 months ago) by hwang
Changes since 1.10: +19 -0 lines
	Added enzyme buttons/text/grid
	Added exit button to allow user to exit normally
Mon Aug 18 15:55:57 2003 UTC (16 years, 3 months ago) by efrank
CVS Tags: V00-00-00, V00-00-01
Changes since 1.9: +11 -0 lines
Start documenting the code a trifle.  All files have been modified by adding
the list of def'd methods at the top of the class.  Must add description
strings, but this is a start.
Thu Aug 7 19:14:27 2003 UTC (16 years, 4 months ago) by efrank
Thu Aug 7 02:39:46 2003 UTC (16 years, 4 months ago) by efrank
adding to Metabolite panel so that we can search for metabolites.
main.py: move some init stuff out of main.py into associated panel.
mainlayout: clean up and reorg a bit.  lots of renames
rxpanel: commented out to speed up startup.
Mon Aug 4 16:18:47 2003 UTC (16 years, 4 months ago) by efrank
Changes since 1.6: +0 -5 lines
more tweaks for making things work.  no fundamental changes.  oh...except
in RecoElemPanel where we now use wxTreeCtrl EVT_TREE_SEL_CHANGED to figure
out when there's a hit on something.  Before, we were not picking up
selections on the top nodes.  That meant that a recoElem with no kids but
*with* reactions could not have its reactions listed.
Mon Aug 4 12:46:49 2003 UTC (16 years, 4 months ago) by efrank
Changes since 1.5: +52 -26 lines
sync with kaitlyn's mods.  add new fn'ality:
Catalogpanel.py:
   o include Wit as Datasource via FaST/WitFactory
   o Catalog tree of data sources expands to basic level at startup
   o to handle multiple data sources:
        We use EVT_TREE_SEL_CHANGED to know when a user has chosen something.
        At that point, we remember the data associated with tree item that was
        set when the item was added to the tree.  That data is a tuple comprising
        (ptr-to-function, arg list). When the load button is hit, it looks at
        this tuple and evaluates ptr-to-fnction on the arg list.  The idea is
        that when the catalog tree is built, it is built by various data-base
        specific functions.  Those functions know the database they are dealing
        with, so they can load the (func, args) correctly to achieve the correct
        behavior.  The point here is that wxPython only allows you set a single
        selection-handler per tree, not per tree item.  Thus we build our own
        little dispatch handler as just described since our tree is really
        heterogeneous.  Get it?
MainLayout.py:
   o Just some name changes, like the title of the window.
Fri Aug 1 20:53:06 2003 UTC (16 years, 4 months ago) by efrank
Changes since 1.4: +14 -7 lines
catalogPanel:
	change so that EVT_TREE_SEL_CHANGED rather than EVT_LEFT_DCLICK so that
	we work through tree as single click.
mainLayout:
	had to latch the Id fro the catalog_tree control
	changed text in some buttons and tabs
Fri Aug 1 18:54:31 2003 UTC (16 years, 4 months ago) by efrank
Changes since 1.3: +72 -12 lines
Catalogpanel:
	modify so that the catalog is a tree.  the top level nodes in the tree
	list the data factories, e.g., Bss, Wit, etc.
main.py
	to match above.
Fri Aug 1 15:33:39 2003 UTC (16 years, 4 months ago) by hwang
Changes since 1.2: +7 -4 lines
Thu Jul 31 15:54:29 2003 UTC (16 years, 4 months ago) by efrank
CVS Tags: efrank-worksBeforeCatalogTree
Changes since 1.1: +16 -10 lines
1) change so that when an item is selected, the load does not start right away.  instead,
   we just rcord which thing was selected.
2) wire in the LOAD button.  the load button handler does the recoelem load refered
   to in 1)
3) stifle some printouts
Mon Jul 28 22:31:13 2003 UTC (16 years, 4 months ago) by hwang
