[Bio] / PyGUI / Catalogpanel.py Repository:
View of /PyGUI/Catalogpanel.py
Revision 1.33 - (download) (as text) (annotate)
Fri Jul 9 19:08:13 2004 UTC (15 years, 5 months ago) by efrank
Changes since 1.32: +9 -7 lines
Had a loop between catalogpanel putting a factory into the catalog
in loadCatalog() and the callback handler in MainLayout for added factories
trying to call into loadCatalog().
got rid of the adding of factories in loadCatalog().
now factory is added in very topmost level (ModelEditor).  the callback
chain/observer takes care of the rest.
from wxPython.wx             import *
from FaST.BssFactory         import BssFactory
from FaST.BssFactoryProxy    import BssFactoryProxy
from FaST.WitFactory         import WitFactory
from FaST.SeedDataFactory    import SeedDataFactory
from FaST.SeedDataFactory    import SeedOrganism
from KahOM.RecoElem           import RecoElem
from PyGUI.RecoElempanel           import RecoElempanel
from CatalogServices.Catalog import Catalog
class Catalogpanel:
    def __init__(self, parent):
        self.parent            = parent
        self.to_re    = parent.re
        self.selected = None       #remember last selected catalog entry
                                   #..is used when LOAD button is hit.
        # seedItemId is the wxPython id for the "Seed" node
        # in the catalog tree under which all specific Seed servers
        # are listed
        self.seedItemId        = None
        self.initCatEvents()
        self.initCatData()
        # setup catalog editing menu (right click)
        self.catEditMenu         = wxMenu()
        self.catEditMkItemId     = wxNewId()
        self.catEditMkDirId      = wxNewId()
        self.setupCatEditMenu()
        return
    def initCatEvents(self):
        EVT_TREE_SEL_CHANGED(self.parent.catalog_tree,
                             self.parent.catalog_treeId,
                             self.onLeftClick)
        # Right click on List item for Seed will let you connect to
        # another Seed server
        EVT_RIGHT_DOWN(self.parent.catalog_tree, self.onRightClickCatalogTree)
        EVT_LEFT_DCLICK (self.parent.catalog_tree, self.onLeftDClick)
        EVT_COMBOBOX(self.parent.catVersionValueComboBox,
                     self.parent.catVersionValueComboBox.GetId(),
                     self.onCatVersionValueComboBox)
        return
    def initCatData( self ):
        self.parent.catalogRootId = self.parent.catalog_tree.AddRoot("/")
        self.loadCatalog()
        self.parent.catalog_tree.Expand( self.parent.catalogRootId)
        return
    def setupCatEditMenu(self):
        self.catEditMenu.Append( self.catEditMkDirId,
                                 "New Directory", "NewDirectory" )
        EVT_MENU(self.parent, self.catEditMkDirId, self.doCatEditMkDir)
        self.catEditMenu.Append( self.catEditMkItemId,
                                 "New Item", "NewDirectory" )
        EVT_MENU(self.parent, self.catEditMkItemId, self.doCatEditMkItem)
        return
    def loadCatalog(self):
        wxBeginBusyCursor()
        #localSeedServer        = "http://localhost/FIG"
        #seedFactory   = SeedDataFactory( localSeedServer )
        #b             = BssFactory()
        #theConnectionInfo = ["terra.mcs.anl.gov", 3000]
        #b             = BssFactoryProxy(theConnectionInfo)
        #try:
        #   Catalog.instance().addDataFactory( b )
        #else:
        #except:
        #    self.parent.error("LoadCatalog: no local Bss database." )
        #    wxEndBusyCursor()
        #    return
        # Handle top/root of catalog/tree specially to avoid "two root"
        # on display problem
        top = Catalog.instance().getCatalogTop()
        parentTree = self.parent.catalog_tree
        parentTree.SetPyData( self.parent.catalogRootId,
                              (self.recoElemLoader, top, self.parent.catalogRootId) )
        for e in top.entries():
            self.recurseCatalog( e, parentTree, self.parent.catalogRootId)
        parentTree.SortChildren( self.parent.catalogRootId)
        wxEndBusyCursor()
        return
    def recurseCatalog( self, catEntry, parentTree, parentItemId):
        Create a new item under parentItemId in wxTree, parentTree.  Associate
        catEntry with it.  If catEntry has entries, recurse on them.
        if ( catEntry.isTerminal() ):
            displayedName = catEntry.name()
        else:
            displayedName = catEntry.name() + "/"
        newItemId=parentTree.AppendItem(parentItemId, displayedName )
        # associate data needed to manipulate the catEntry
        parentTree.SetPyData( newItemId,
                              (self.recoElemLoader, catEntry, newItemId ) )
        if ( not catEntry.isTerminal() ):
            for e in catEntry.entries():
                self.recurseCatalog( e, parentTree, newItemId)
        parentTree.SortChildren( newItemId )
        return
    def DOOMloadSeedCatalog(self, seedServer ):
        This adds a Seed instance to the catalog.  It is called from the
        MainMenuBar when Data->Add Seed Instance is called, for example.
        wxBeginBusyCursor()
	# The SeedDataFactory ctor is slow and actually reads a bunch of
	# data from the server
        seedFactory   = SeedDataFactory( seedServer )
        # add it to the list in the catalog
        try:
            Catalog.instance().addDataFactory( seedFactory )
        except:
            self.parent.error("loadSeedCatalog: %s already in foundry list." % seedServer)
            wxEndBusyCursor()
            return
        top = seedFactory.getCatalogTop()
        self.recurseCatalog( top, self.parent.catalog_tree, self.parent.catalogRootId)
        wxEndBusyCursor()
        return
    def onLeftClick(self,treeEvent):
        item = treeEvent.GetItem()
        catEntryTuple = self.parent.tree_ctr.GetPyData(item)
        if (catEntryTuple == None ):
            return
        self.selected = catEntryTuple
        catEntry   = catEntryTuple[1]
        # update the history information display
        theBox = self.parent.catVersionValueComboBox
        theBox.Clear()
            self.parent.catPathValue.SetValue( catEntry.path() + "/" )
            self.parent.catVersionValueComboBox.SetLabel( "")
            self.parent.catHistoryDateValue.SetLabel( "" )
            self.parent.catHistoryUserValue.SetLabel( "" )
            self.parent.catHistoryCreatedFromValue.SetLabel( "")
            theBox.SetValue( "" )
        else:
            versions   = catEntry.versions()
            if ( [] == versions ):
                self.parent.catPathValue.SetLabel( catEntry.path()+";[None]" )
                theBox.SetValue( "None" )
            else:
                maxVersion = max( versions )
                for v in versions:
                    theBox.Append( "%s" % (v ) )
                    theBox.SetValue( "%s" % (maxVersion) )
                self.parent.catPathValue.SetLabel(catEntry.path()+";[%s]" % (maxVersion))
            self.parent.catHistoryDateValue.SetLabel( "no date info yet" )
            self.parent.catHistoryUserValue.SetLabel( "no user info yet" )
            self.parent.catHistoryCreatedFromValue.SetLabel( "no history info yet" )
        return
    def onCatVersionValueComboBox(self, event):
        Handles activity in combo box where user sets Verion to use
        # get the value selected in the combo box.
        choice = event.GetString()
        self.parent.catVersionValueComboBox.SetValue( "%s" % (choice) )
        # the operation is interpreted relative to the currently selected
        # catalogEntry.  find what that is.
        catEntry   = self.selected[1]
        # update stuff
        #version = self.parent.catVersionValueComboBox.GetValue()
        self.parent.catPathValue.SetLabel( catEntry.path()+";[%s]" % (choice) )
        return
    def onRightClickCatalogTree(self, event):
        """ Fires off the pop-up menu to handle right click events. """
        event.GetEventObject().PopupMenu(self.catEditMenu, event.GetPosition())
        return
    def doCatEditMkDir( self, event ):
        if (None == self.selected):
            self.parent.error( "A selection is required first.")
            return
        catEntryTuple = self.selected
        treeItemId    = catEntryTuple[2]
        if (catEntry.isTerminal()):
            self.parent.error("Directories can not be added to items.")
            return
        prompt = "New catalog directory name:"
        dlg = wxTextEntryDialog(self.parent, message=prompt, style=wxOK)
        if ( dlg.ShowModal() == wxID_OK):
            theName = dlg.GetValue()
            if ( theName=="" ): return
            dlg.Destroy()
        else:
            #didn't get a kid name
            dlg.Destroy()
            return
        try:
            newCatEntry=catEntry.mkDir( theName )
            parentTree=self.parent.catalog_tree
            newItemId=parentTree.AppendItem(treeItemId, newCatEntry.name() )
                                  (self.recoElemLoader, newCatEntry, newItemId )  )
            parentTree.SortChildren( treeItemId )
        except:
            self.parent.error( "Operation refused." )
        return
    def doCatEditMkItem( self, event ):
            return
            self.parent.error("Items can not be added to items. Add to a directory.")
            return
        prompt = "New catalog entry name:"
            dlg.Destroy()
        else:
            dlg.Destroy()
            return
        try:
            newCatEntry = catEntry.mkItem( theName )
        except:
        return
    def onLeftDClick(self, event):
        """ Double left-click means, "Load the currently selected item." """
        if ( self.selected == None ):
            self.parent.error( "You must select a catalog entry before requesting load.")
            return
        # We store a loader to actually load the selected item.  This dates
        # back to a time before a single loader could handle all the various
        # data factory kinds.
        apply( catEntryTuple[0], [catEntryTuple[1]] )
        return
    def recoElemLoader(self,  argList ):
        wxBeginBusyCursor()
        (catalogEntry) = argList
        if (catalogEntry.isTerminal() ):
            ver = self.parent.catVersionValueComboBox.GetValue()
            if ( ver == "None" ):
                top = RecoElem( catalogEntry.name() )
            else:
                top = catalogEntry.read( int( ver ) )
            self.to_re.addRecoElemTree(self.parent.rootId, top, catalogEntry)
        else:
            # current selection is directory. can't load that!
            wxEndBusyCursor()
            return
        wxEndBusyCursor()
        return
    def DOOMwitPwyLoader(self,  pwyName ):
        wxBeginBusyCursor()
        w=WitFactory()
        top= w.getRxnByPwy( pwyName )
        self.to_re.addRecoElemTree(self.parent.rootId, top)
        wxEndBusyCursor()
        return
