[Bio] / PyGUI / Catalogpanel.py Repository:
View of /PyGUI/Catalogpanel.py
Revision 1.25 - (download) (as text) (annotate)
Wed May 26 01:38:25 2004 UTC (15 years, 6 months ago) by efrank
Changes since 1.24: +251 -28 lines
Lots of work aimed at getting catalog services to work, incorporating
catalog editing into the model editor, and simplifying the api
for going form path to model in hand to work with.
CatalogEntryTop was changed to CatalogEntrBase and made base of CatalogEntry
rather than other way around to break a dependency loop that was causing
python import problems.  CatalogEntry is still the base class to use
for extending to new data factories.
changed open() to return catalogEntry rather than foundryItemKey.  simpler
for the user and more opportunity to encapsulate.
made catalogEntry able to read a recoElem and return it.  all done in
terms of arch abstractions.  this is temorary.  we will add a Navigator
or Manager class and that will be returned from the CatalogEntry rather
than recoElem.  that's becausee Recoelem is just one of many things
that will be present, e.g., conditions data.
PyGui/MainMenuBar.  split out to help stay sane for when that becomes
more complex.
Moved add seed server to menu bar so that right click in catalog panel
coudl be used to pull up catalog editing tools.
from wxPython.wx             import *
from FaST.BssFactory         import BssFactory
from FaST.WitFactory         import WitFactory
from FaST.SeedDataFactory    import SeedDataFactory
from FaST.SeedDataFactory    import SeedOrganism
from FaST.RecoElem           import RecoElem
from RecoElempanel           import RecoElempanel
from CatalogServices.Catalog import Catalog
class Catalogpanel:
#    def __init__(self, parent):
#    def initCatEvents(self ):
#    def initCatData( self ):
#    def loadBssCatalog(self, bssItemId):
#    def loadWitCatalog(self, witItemId):
#    def loadSeedCatalog(self, witItemId):
#    def onLeftClick(self,treeEvent):
#    def onLoadBtnPress(self, event):
#    def bssLoader( self, bssCatEntry ):
#    def witOrgLoader(self,  orgName ):
#    def witPwyLoader(self,  pwyName ):
        self.parent            = parent
        self.to_re    = parent.re
        self.selected = None       #remember last selected catalog entry
                                   #..is used when LOAD button is hit.
        # seedItemId is the wxPython id for the "Seed" node
        # in the catalog tree under which all specific Seed servers
        # are listed
        self.seedItemId        = None
        self.initCatEvents()
        self.initCatData()
        # setup catalog editing menu (right click)
        self.catEditMenu         = wxMenu()
        self.catEditMkItemId     = wxNewId()
        self.catEditMkDirId      = wxNewId()
        self.setupCatEditMenu()
        return
        EVT_TREE_SEL_CHANGED(self.parent.catalog_tree,
                             self.parent.catalog_treeId,
                             self.onLeftClick)
        # Right click on List item for Seed will let you connect to
        # another Seed server
        EVT_RIGHT_DOWN(self.parent.catalog_tree, self.onRightClickCatalogTree)
        EVT_LEFT_DCLICK (self.parent.catalog_tree, self.onLeftDClick)
        EVT_COMBOBOX(self.parent.catVersionValueComboBox,
                     self.parent.catVersionValueComboBox.GetId(),
                     self.onCatVersionValueComboBox)
        return
        self.parent.catalogRootId = self.parent.catalog_tree.AddRoot("Data Sources")
        #bssItemId=self.parent.catalog_tree.AppendItem(self.parent.catalogRootId,
        #                                           "BioSimScratch" )
        #witItemId=self.parent.catalog_tree.AppendItem(self.parent.catalogRootId,
        #                                           "WIT3" )
        #self.seedItemId=self.parent.catalog_tree.AppendItem(self.parent.catalogRootId,
        #                                           "Seed" )
        #self.loadBssCatalog( bssItemId )
        #self.loadWitCatalog( witItemId )
        localSeedServer        = "http://localhost/FIG/"
#        localSeedServer        = "http://float179.mcs.anl-external.org/FIG/"
        #self.loadSeedCatalog( localSeedServer)
        self.loadCatalog()
        self.parent.catalog_tree.Expand( self.parent.catalogRootId)
        return
    def setupCatEditMenu(self):
        self.catEditMenu.Append( self.catEditMkDirId,
                                 "New Directory", "NewDirectory" )
        EVT_MENU(self.parent, self.catEditMkDirId, self.doCatEditMkDir)
        self.catEditMenu.Append( self.catEditMkItemId,
                                 "New Item", "NewDirectory" )
        EVT_MENU(self.parent, self.catEditMkItemId, self.doCatEditMkItem)
        return
        b=BssFactory()
        Catalog.instance().addDataFactory( b )
        for catEntryTuple in b.getLsCat():
            id=self.parent.catalog_tree.AppendItem(bssItemId, catEntryTuple[0])
            self.parent.catalog_tree.SetPyData(id, (self.bssLoader, catEntryTuple, id) )
        return
        w=WitFactory()
        Catalog.instance().addDataFactory( w )
        pwyItemId=self.parent.catalog_tree.AppendItem(witItemId, "Pathways" )
        pwyList = w.listPathways( )
        for pwy in pwyList:
            id=self.parent.catalog_tree.AppendItem(pwyItemId, pwy)
            self.parent.catalog_tree.SetPyData(id, (self.witPwyLoader,pwy, id) )
        orgItemId=self.parent.catalog_tree.AppendItem(witItemId, "Organisms" )
        orgList = w.listOrganisms( )
        for org in orgList:
            id=self.parent.catalog_tree.AppendItem(orgItemId, org)
            self.parent.catalog_tree.SetPyData(id, (self.witOrgLoader, org, id ))
        return
    def loadCatalog(self):
        wxBeginBusyCursor()
        seedFactory   = SeedDataFactory( localSeedServer )
        b             = BssFactory()
        try:
            Catalog.instance().addDataFactory( seedFactory )
        except:
            self.parent.error("loadCatalog: error" )
            wxEndBusyCursor()
            return
        top = Catalog.instance().getCatalogTop()
        self.recurseCatalog( top, self.parent.catalog_tree, self.parent.catalogRootId)
        wxEndBusyCursor()
        return
    def loadSeedCatalog(self, seedServer ):
        wxBeginBusyCursor()
        seedFactory   = SeedDataFactory( seedServer )
        # add it to the list in the catalog
        try:
        except:
            self.parent.error("loadSeedCatalog: %s already in foundry list." % seedServer)
            wxEndBusyCursor()
            return
        top = seedFactory.getCatalogTop()
        #self.recurseCatalog( top, self.parent.catalog_tree, self.seedItemId )
        wxEndBusyCursor()
        return
    def recurseCatalog( self, catEntry, parentTree, parentItemId):
        terminal nodes have FoundryItemKeys associated with them that we
        can read if requested.  associate that key and a handler with the
        wxTree item in that case.
        newItemId=parentTree.AppendItem(parentItemId, catEntry.name() )
        parentTree.SetPyData( newItemId,
                              (self.recoElemLoader, catEntry, newItemId )
        if ( not catEntry.isTerminal() ):
            for e in catEntry.entries():
                self.recurseCatalog( e, parentTree, newItemId)
        # not efficient becaure of re-sort
        parentTree.SortChildren( newItemId )
        return
    def OLDloadSeedCatalog(self, seedServer ):
        wxBeginBusyCursor()
	# The SeedDataFactory ctor is slow and actually reads a bunch of
	# data from the server
        try:
        except:
            wxEndBusyCursor()
            return
	# make an entry in the tree for it
        newSeedItemId=self.parent.catalog_tree.AppendItem(self.seedItemId, seedServer )
	# jam in the data
        orgList = seedFactory.listOrganisms( )
        if ( orgList== None ):
            orgItemId=self.parent.catalog_tree.AppendItem(newSeedItemId,
                         "Could not get Org list from "+ seedServer )
            wxEndBusyCursor()
            return
        itemName="Spontaneous Reactions"
        spontaneousRxItemId=self.parent.catalog_tree.AppendItem(newSeedItemId, itemName)
        self.parent.catalog_tree.SetPyData(spontaneousRxItemId,
                                           (self.seedRecoElemLoader,
                                           (seedFactory.getRecoElemSpontaneousRx, None),
                                            spontaneousRxItemId ))
        orgItemId=self.parent.catalog_tree.AppendItem(newSeedItemId, "Organisms" )
        for org in orgList:
            id=self.parent.catalog_tree.AppendItem(orgItemId, org.figOrgName )
            self.parent.catalog_tree.SetPyData(id, (self.seedRecoElemLoader,
                                                   (seedFactory.getRecoElemByOrg, org), id) )
        wxEndBusyCursor()
        return
        item = treeEvent.GetItem()
        catEntryTuple = self.parent.tree_ctr.GetPyData(item)
        if (catEntryTuple == None ):
            print "None value for catEntryTuple"
            return
        self.selected = catEntryTuple
        catEntry   = catEntryTuple[1]
        # update the history information display
        theBox = self.parent.catVersionValueComboBox
        theBox.Clear()
            self.parent.catPathValue.SetLabel( catEntry.path() )
            self.parent.catVersionValueComboBox.SetLabel( "")
            self.parent.catHistoryDateValue.SetLabel( "" )
            self.parent.catHistoryUserValue.SetLabel( "" )
            self.parent.catHistoryCreatedFromValue.SetLabel( "")
        else:
            versions   = catEntry.versions()
            if ( [] == versions ):
                self.parent.catPathValue.SetLabel( catEntry.path()+";[None]" )
            else:
                maxVersion = max( versions )
                for v in versions:
                    theBox.Append( "%s" % (v ) )
                    theBox.SetValue( "%s" % (maxVersion) )
                self.parent.catPathValue.SetLabel(catEntry.path()+";[%s]" % (maxVersion))
            self.parent.catHistoryDateValue.SetLabel( "no date info yet" )
            self.parent.catHistoryUserValue.SetLabel( "no user info yet" )
            self.parent.catHistoryCreatedFromValue.SetLabel( "no history info yet" )
        return
    def onCatVersionValueComboBox(self, event):
        Handles activity in combo box where user sets Verion to use
        # get the value selected in the combo box.
        choice = event.GetString()
        # the operation is interpreted relative to the currently selected
        # catalogEntry.  find what that is.
        catEntry   = self.selected[1]
        # update stuff
        #version = self.parent.catVersionValueComboBox.GetValue()
        self.parent.catPathValue.SetLabel( catEntry.path()+";[%s]" % (choice) )
        return
    def onRightClickCatalogTree(self, event):
        goober = event.GetEventObject()
        goober.PopupMenu(self.catEditMenu, event.GetPosition())
        return
    def doCatEditMkDir( self, event ):
        if (None == self.selected):
            self.parent.error( "A selection is required first.")
            return
        catEntryTuple = self.selected
        treeItemId    = catEntryTuple[2]
        if (catEntry.isTerminal()):
            self.parent.error("Directories can not be added to items.")
            return
        prompt = "New catalog directory name:"
        dlg = wxTextEntryDialog(self.parent, message=prompt, style=wxOK)
        if ( dlg.ShowModal() == wxID_OK):
            theName = dlg.GetValue()
            if ( theName=="" ): return
            dlg.Destroy()
        else:
            #didn't get a kid name
            dlg.Destroy()
            return
        try:
            newCatEntry=catEntry.mkDir( theName )
            parentTree=self.parent.catalog_tree
            newItemId=parentTree.AppendItem(treeItemId, newCatEntry.name() )
                                  (self.recoElemLoader, newCatEntry, newItemId )  )
            parentTree.SortChildren( treeItemId )
        except:
            self.parent.error( "Operation refused." )
        return
    def doCatEditMkItem( self, event ):
            return
            self.parent.error("Items can not be added to items. Add to a directory.")
            return
        prompt = "New catalog entry name:"
            dlg.Destroy()
        else:
            dlg.Destroy()
            return
        try:
            newCatEntry = catEntry.mkItem( theName )
        except:
        return
    def onLeftDClick(self, event):
        if ( self.selected == None ):
            print "No selection in onLoadBtnPress"
            return
        apply( catEntryTuple[0], [catEntryTuple[1]] )
        return
    def recoElemLoader(self,  argList ):
        wxBeginBusyCursor()
        (catalogEntry) = argList
        if (catalogEntry.isTerminal() ):
            top = catalogEntry.getRecoElem()
            self.to_re.AddRecoElemTree(self.parent.rootId, top, catalogEntry)
        else:
            # current selection is directory. can't load that!
            wxEndBusyCursor()
            return
        wxEndBusyCursor()
        return
        wxBeginBusyCursor()
        b=BssFactory()
        top= b.getRecoElemById( bssCatEntry[1] )
        self.to_re.AddRecoElemTree(self.parent.rootId, top)
        wxEndBusyCursor()
        return
        wxBeginBusyCursor()
        w=WitFactory()
        top= w.getRxnByOrg( orgName )
        wxEndBusyCursor()
        return
    def seedRecoElemLoader(self,  argList ):
        wxBeginBusyCursor()
        (theSeedFactoryMethod, org) = argList
        top = apply( theSeedFactoryMethod, [org] )
        # top=self.__seedDataFactory.getRecoElemByOrg( org )
        wxEndBusyCursor()
        return
        wxBeginBusyCursor()
        w=WitFactory()
        top= w.getRxnByPwy( pwyName )
        wxEndBusyCursor()
        return
