[Bio] / PyGUI / Catalogpanel.py Repository:
View of /PyGUI/Catalogpanel.py
Revision 1.21 - (download) (as text) (annotate)
Wed Feb 25 17:08:17 2004 UTC (15 years, 10 months ago) by hwang
Changes since 1.20: +5 -4 lines
     Changed all the files so that the past inconsistancies of variable and classes names
 are consistant. I.E. MainLayout import MainLayout.
     In MainLayout, separate functions are made for each panel.
from wxPython.wx import *
from FaST.BssFactory import BssFactory
from FaST.WitFactory import WitFactory
from FaST.SeedDataFactory import SeedDataFactory
from FaST.SeedDataFactory import SeedOrganism
from FaST.RecoElem import RecoElem
from RecoElempanel import RecoElempanel
class Catalogpanel:
#    def __init__(self, parent):
#    def initCatEvents(self ):
#    def initCatData( self ):
#    def loadBssCatalog(self, bssItemId):
#    def loadWitCatalog(self, witItemId):
#    def loadSeedCatalog(self, witItemId):
#    def onLeftClick(self,treeEvent):
#    def onLoadBtnPress(self, event):
#    def bssLoader( self, bssCatEntry ):
#    def witOrgLoader(self,  orgName ):
#    def witPwyLoader(self,  pwyName ):
        self.parent            = parent
        self.to_re    = parent.re
        self.selected = None       #remember last selected catalog entry
                                   #..is used when LOAD button is hit.
        # seedItemId is the wxPython id for the "Seed" node
        # in the catalog tree under which all specific Seed servers
        # are listed
        self.seedItemId        = None
        self.initCatEvents()
        self.initCatData()
        self.seedServerMenu = wxMenu()
        self.seedServerAddId = wxNewId()
        self.setupSeedServerMenu()
        return
        #button1= self.parent.OK_button
        button1= self.parent.loadbtn
        EVT_BUTTON(self.parent, self.parent.loadbtn.GetId(),
                  self.onLoadBtnPress)
        EVT_TREE_SEL_CHANGED(self.parent.catalog_tree,
                             self.parent.catalog_treeId,
                             self.onLeftClick)
        # Right click on List item for Seed will let you connect to
        # another Seed server
        EVT_RIGHT_DOWN(self.parent.catalog_tree, self.onRightClickCatalogTree)
        EVT_LEFT_DCLICK (self.parent.catalog_tree, self.onLoadBtnPress)
        return
        self.parent.catalogRootId = self.parent.catalog_tree.AddRoot("Data Sources")
        bssItemId=self.parent.catalog_tree.AppendItem(self.parent.catalogRootId,
                                                   "BioSimScratch" )
        witItemId=self.parent.catalog_tree.AppendItem(self.parent.catalogRootId,
                                                   "WIT3" )
        self.seedItemId=self.parent.catalog_tree.AppendItem(self.parent.catalogRootId,
                                                   "Seed" )
        self.loadBssCatalog( bssItemId )
        self.loadWitCatalog( witItemId )
        localSeedServer        = "http://localhost/FIG/"
#        localSeedServer        = "http://float179.mcs.anl-external.org/FIG/"
        self.loadSeedCatalog( localSeedServer)
        self.parent.catalog_tree.Expand( self.parent.catalogRootId)
        return
    def setupSeedServerMenu(self):
        self.seedServerMenu.Append( self.seedServerAddId,
                                      "Add Seed Server", "New seed server arg3" )
        EVT_MENU(self.parent, self.seedServerAddId, self.doSeedServerAdd)
        b=BssFactory()
        for catEntryTuple in b.getLsCat():
            id=self.parent.catalog_tree.AppendItem(bssItemId, catEntryTuple[0])
            self.parent.catalog_tree.SetPyData(id, (self.bssLoader, catEntryTuple) )
        return
        w=WitFactory()
        pwyItemId=self.parent.catalog_tree.AppendItem(witItemId, "Pathways" )
        pwyList = w.listPathways( )
        for pwy in pwyList:
            id=self.parent.catalog_tree.AppendItem(pwyItemId, pwy)
            self.parent.catalog_tree.SetPyData(id, (self.witPwyLoader,pwy) )
        orgItemId=self.parent.catalog_tree.AppendItem(witItemId, "Organisms" )
        orgList = w.listOrganisms( )
        for org in orgList:
            id=self.parent.catalog_tree.AppendItem(orgItemId, org)
            self.parent.catalog_tree.SetPyData(id, (self.witOrgLoader, org ))
        return
    def loadSeedCatalog(self, seedServer ):
        wxBeginBusyCursor()
	# The SeedDataFactory ctor is slow and actually reads a bunch of
	# data from the server
        seedFactory   = SeedDataFactory( seedServer )
        # add it to the list in the catalog
        try:
            self.parent.factoryMgr.addFactory( seedServer, seedFactory )
        except:
            self.parent.error("loadSeedCatalog: %s already in foundry list." % seedServer)
            wxEndBusyCursor()
            return
	# make an entry in the tree for it
        newSeedItemId=self.parent.catalog_tree.AppendItem(self.seedItemId, seedServer )
	# jam in the data
        orgList = seedFactory.listOrganisms( )
        if ( orgList== None ):
            orgItemId=self.parent.catalog_tree.AppendItem(newSeedItemId,
                         "Could not get Org list from "+ seedServer )
            wxEndBusyCursor()
            return
        itemName="Spontaneous Reactions"
        spontaneousRxItemId=self.parent.catalog_tree.AppendItem(newSeedItemId, itemName)
        self.parent.catalog_tree.SetPyData(spontaneousRxItemId,
                                           (self.seedRecoElemLoader,
                                           (seedFactory.getRecoElemSpontaneousRx, None) ))
        orgItemId=self.parent.catalog_tree.AppendItem(newSeedItemId, "Organisms" )
        for org in orgList:
            id=self.parent.catalog_tree.AppendItem(orgItemId, org.figOrgName )
            self.parent.catalog_tree.SetPyData(id, (self.seedRecoElemLoader,
                                                   (seedFactory.getRecoElemByOrg, org) ))
        wxEndBusyCursor()
        return
        item = treeEvent.GetItem()
        catEntryTuple = self.parent.tree_ctr.GetPyData(item)
        if (catEntryTuple == None ):
            return
        self.selected = catEntryTuple
        return
    def onRightClickCatalogTree(self, event):
        goober = event.GetEventObject()
        goober.PopupMenu(self.seedServerMenu, event.GetPosition())
        return
    def doSeedServerAdd(self, event):
        prompt = "Name of Seed server"
        dlg = wxTextEntryDialog(self.parent, message=prompt, style=wxOK)
        if ( dlg.ShowModal() == wxID_OK):
            serverName = dlg.GetValue()
            if ( serverName=="" ): return
            dlg.Destroy()
        else:
            #didn't get a kid name
            dlg.Destroy()
            return
        self.loadSeedCatalog( serverName )
        return
    def onLeftDClick(self,treeEvent):
        self.onLoadBtnPress(treeEvent)
        pt = treeEvent.GetPosition()
        item = self.parent.tree_ctr.HitTest(pt)
        print item
        apply(catEntryTuple[0], catEntryTuple[1])
        return
        print item
        #print catEntryTuple, "catEntryTuple"
        #self.selected = catEntryTuple
        #catEntryTuple = self.selected
        #apply(catEntryTuple[0], [catEntryTuple[1]])
        return
        if ( self.selected == None ):
            print "No selection in onLoadBtnPress"
            return
        apply( catEntryTuple[0], [catEntryTuple[1]] )
        return
        wxBeginBusyCursor()
        b=BssFactory()
        top= b.getRecoElemById( bssCatEntry[1] )
        self.to_re.AddRecoElemTree(self.parent.rootId, top)
        wxEndBusyCursor()
        return
        wxBeginBusyCursor()
        w=WitFactory()
        top= w.getRxnByOrg( orgName )
        wxEndBusyCursor()
        return
    def seedRecoElemLoader(self,  argList ):
        wxBeginBusyCursor()
        (theSeedFactoryMethod, org) = argList
        top = apply( theSeedFactoryMethod, [org] )
        # top=self.__seedDataFactory.getRecoElemByOrg( org )
        wxEndBusyCursor()
        return
        wxBeginBusyCursor()
        w=WitFactory()
        top= w.getRxnByPwy( pwyName )
        wxEndBusyCursor()
        return
