[Bio] / PyGUI / Catalogpanel.py Repository:
View of /PyGUI/Catalogpanel.py
Revision 1.18 - (download) (as text) (annotate)
Thu Nov 13 19:21:46 2003 UTC (16 years, 1 month ago) by efrank
back to localhost for init
from wxPython.wx import *
from FaST.BssFactory import BssFactory
from FaST.WitFactory import WitFactory
from FaST.SeedDataFactory import SeedDataFactory
from FaST.SeedDataFactory import SeedOrganism
from FaST.RecoElem import RecoElem
from RecoElempanel import RecoElemWindow
class CatalogWindow:
#    def __init__(self, parent):
#    def initCatEvents(self ):
#    def initCatData( self ):
#    def loadBssCatalog(self, bssItemId):
#    def loadWitCatalog(self, witItemId):
#    def loadSeedCatalog(self, witItemId):
#    def onLeftClick(self,treeEvent):
#    def onLoadBtnPress(self, event):
#    def bssLoader( self, bssCatEntry ):
#    def witOrgLoader(self,  orgName ):
#    def witPwyLoader(self,  pwyName ):
        self.parent            = parent
        self.to_re    = parent.re
        self.selected = None       #remember last selected catalog entry
                                   #..is used when LOAD button is hit.
        # seedItemId is the wxPython id for the "Seed" node
        # in the catalog tree under which all specific Seed servers
        # are listed
        self.seedItemId        = None
        self.initCatEvents()
        self.initCatData()
        self.seedServerMenu = wxMenu()
        self.seedServerAddId = wxNewId()
        self.setupSeedServerMenu()
        return
        button1= self.parent.OK_button
        EVT_BUTTON(self.parent, self.parent.loadbtn.GetId(),
                   self.onLoadBtnPress)
        EVT_TREE_SEL_CHANGED(self.parent.catalog_tree,
                             self.parent.catalog_treeId,
                             self.onLeftClick)
        # Right click on List item for Seed will let you connect to
        # another Seed server
        EVT_RIGHT_DOWN(self.parent.catalog_tree, self.onRightClickCatalogTree)
        # doesn't work...
        # EVT_LEFT_DCLICK (self.parent.catalog_tree, self.onLeftDClick)
        return
        self.parent.catalogRootId = self.parent.catalog_tree.AddRoot("Data Sources")
        bssItemId=self.parent.catalog_tree.AppendItem(self.parent.catalogRootId,
                                                   "BioSimScratch" )
        witItemId=self.parent.catalog_tree.AppendItem(self.parent.catalogRootId,
                                                   "WIT3" )
        self.seedItemId=self.parent.catalog_tree.AppendItem(self.parent.catalogRootId,
                                                   "Seed" )
        self.loadBssCatalog( bssItemId )
        self.loadWitCatalog( witItemId )
        localSeedServer        = "http://localhost/FIG/"
#        localSeedServer        = "http://float179.mcs.anl-external.org/FIG/"
        self.loadSeedCatalog( localSeedServer)
        self.parent.catalog_tree.Expand( self.parent.catalogRootId)
        return
    def setupSeedServerMenu(self):
        self.seedServerMenu.Append( self.seedServerAddId,
                                      "Add Seed Server", "New seed server arg3" )
        EVT_MENU(self.parent, self.seedServerAddId, self.doSeedServerAdd)
        b=BssFactory()
        for catEntryTuple in b.getLsCat():
            id=self.parent.catalog_tree.AppendItem(bssItemId, catEntryTuple[0])
            self.parent.catalog_tree.SetPyData(id, (self.bssLoader, catEntryTuple) )
        return
        w=WitFactory()
        pwyItemId=self.parent.catalog_tree.AppendItem(witItemId, "Pathways" )
        pwyList = w.listPathways( )
        for pwy in pwyList:
            id=self.parent.catalog_tree.AppendItem(pwyItemId, pwy)
            self.parent.catalog_tree.SetPyData(id, (self.witPwyLoader,pwy) )
        orgItemId=self.parent.catalog_tree.AppendItem(witItemId, "Organisms" )
        orgList = w.listOrganisms( )
        for org in orgList:
            id=self.parent.catalog_tree.AppendItem(orgItemId, org)
            self.parent.catalog_tree.SetPyData(id, (self.witOrgLoader, org ))
        return
    def loadSeedCatalog(self, seedServer ):
        wxBeginBusyCursor()
	# The SeedDataFactory ctor is slow and actually reads a bunch of
	# data from the server
        seedFactory   = SeedDataFactory( seedServer )
        # add it to the list in the catalog
        self.parent.factoryMgr.addFactory( seedServer, seedFactory )
	# make an entry in the tree for it
        newSeedItemId=self.parent.catalog_tree.AppendItem(self.seedItemId, seedServer )
	# jam in the data
        orgList = seedFactory.listOrganisms( )
        if ( orgList== None ):
            orgItemId=self.parent.catalog_tree.AppendItem(newSeedItemId,
                         "Could not get Org list from "+ seedServer )
            wxEndBusyCursor()
            return
        itemName="Spontaneous Reactions"
        spontaneousRxItemId=self.parent.catalog_tree.AppendItem(newSeedItemId, itemName)
        self.parent.catalog_tree.SetPyData(spontaneousRxItemId,
                                           (self.seedRecoElemLoader,
                                           (seedFactory.getRecoElemSpontaneousRx, None) ))
        orgItemId=self.parent.catalog_tree.AppendItem(newSeedItemId, "Organisms" )
        for org in orgList:
            id=self.parent.catalog_tree.AppendItem(orgItemId, org.figOrgName )
            self.parent.catalog_tree.SetPyData(id, (self.seedRecoElemLoader,
                                                   (seedFactory.getRecoElemByOrg, org) ))
        wxEndBusyCursor()
        return
        item = treeEvent.GetItem()
        catEntryTuple = self.parent.tree_ctr.GetPyData(item)
        if (catEntryTuple == None ):
            return
        self.selected = catEntryTuple
        return
    def onRightClickCatalogTree(self, event):
        goober = event.GetEventObject()
        goober.PopupMenu(self.seedServerMenu, event.GetPosition())
        return
    def doSeedServerAdd(self, event):
        prompt = "Name of Seed server"
        dlg = wxTextEntryDialog(self.parent, message=prompt, style=wxOK)
        if ( dlg.ShowModal() == wxID_OK):
            serverName = dlg.GetValue()
            if ( serverName=="" ): return
            dlg.Destroy()
        else:
            #didn't get a kid name
            dlg.Destroy()
            return
        self.loadSeedCatalog( serverName )
        return
    def onLeftDClick(self,treeEvent):
        self.onLoadBtnPress(treeEvent)
        pt = treeEvent.GetPosition()
        item = self.parent.tree_ctr.HitTest(pt)
        print item
        apply(catEntryTuple[0], catEntryTuple[1])
        return
        print item
        #print catEntryTuple, "catEntryTuple"
        #self.selected = catEntryTuple
        #catEntryTuple = self.selected
        #apply(catEntryTuple[0], [catEntryTuple[1]])
        return
        if ( self.selected == None ):
            print "No selection in onLoadBtnPress"
            return
        apply( catEntryTuple[0], [catEntryTuple[1]] )
        return
        wxBeginBusyCursor()
        b=BssFactory()
        top= b.getRecoElemById( bssCatEntry[1] )
        self.to_re.AddRecoElemTree(self.parent.rootId, top)
        wxEndBusyCursor()
        return
        wxBeginBusyCursor()
        w=WitFactory()
        top= w.getRxnByOrg( orgName )
        wxEndBusyCursor()
        return
    def seedRecoElemLoader(self,  argList ):
        wxBeginBusyCursor()
        (theSeedFactoryMethod, org) = argList
        top = apply( theSeedFactoryMethod, [org] )
        # top=self.__seedDataFactory.getRecoElemByOrg( org )
        wxEndBusyCursor()
        return
        wxBeginBusyCursor()
        w=WitFactory()
        top= w.getRxnByPwy( pwyName )
        wxEndBusyCursor()
        return
