[Bio] / PyGUI / Catalogpanel.py Repository:
Log of /PyGUI/Catalogpanel.py
Links to V00-00-02: (view) (download) (as text) (annotate)
Wed Jun 9 22:36:10 2004 UTC (15 years, 7 months ago) by efrank
CVS Tags: V00-00-02, forKubal-15Jun04
Changes since 1.25: +54 -46 lines
Diff to previous 1.25 , to selected 1.18
o clean up double foundryId problem in FoundryItems
o change names in CatalogEntry to read() and write()
o write the write() method just mentioned
o get writing to work again, propagate changes into PyGUI
o add plugin capability to modelEditor
Wed May 26 01:38:25 2004 UTC (15 years, 7 months ago) by efrank
Changes since 1.24: +251 -28 lines
Diff to previous 1.24 , to selected 1.18
Lots of work aimed at getting catalog services to work, incorporating
catalog editing into the model editor, and simplifying the api
for going form path to model in hand to work with.
CatalogEntryTop was changed to CatalogEntrBase and made base of CatalogEntry
rather than other way around to break a dependency loop that was causing
python import problems.  CatalogEntry is still the base class to use
for extending to new data factories.
changed open() to return catalogEntry rather than foundryItemKey.  simpler
for the user and more opportunity to encapsulate.
made catalogEntry able to read a recoElem and return it.  all done in
terms of arch abstractions.  this is temorary.  we will add a Navigator
or Manager class and that will be returned from the CatalogEntry rather
than recoElem.  that's becausee Recoelem is just one of many things
that will be present, e.g., conditions data.
PyGui/MainMenuBar.  split out to help stay sane for when that becomes
more complex.
Moved add seed server to menu bar so that right click in catalog panel
coudl be used to pull up catalog editing tools.
Fri Mar 26 17:12:46 2004 UTC (15 years, 9 months ago) by efrank
Changes since 1.23: +11 -10 lines
Diff to previous 1.23 , to selected 1.18
Modifications to install the new Catalog code, FoundryId stuff.  I ripped
out old code as well:  the list of foundryComboBoxes is gone since we now
have just one combo box.
the notion of FoundryId's intVal is gone.  at least for the moment.  it's too hard
at the mment to have a (bottleneck!) central authority to manage the intVals.
so, starting now, foundryId's are based on strings that are notionally URLs and
its up to the dataFoundry manager to make sure all distinct instances at his
site have distinct urls.
this also means that if a foundry moves, then the history information that
refers to it becomes incorrect.
Thu Mar 25 00:49:56 2004 UTC (15 years, 10 months ago) by efrank
Diff to previous 1.22 , to selected 1.18
Migrating to new Catalog, Catlogentry, etc.  This is an intermediary
sync
Fri Mar 5 19:30:38 2004 UTC (15 years, 10 months ago) by hwang
Changes since 1.21: +3 -32 lines
Diff to previous 1.21 , to selected 1.18
	Catalogpanel.py
		Got rid of the "Load to Navigator" button
	FontManager.py
		fixed variable consistancy
	MainLayout.py
		Added combobox label and got rid of "Load to Navigator" button
Wed Feb 25 17:08:17 2004 UTC (15 years, 10 months ago) by hwang
Changes since 1.20: +5 -4 lines
Diff to previous 1.20 , to selected 1.18
     Changed all the files so that the past inconsistancies of variable and classes names
 are consistant. I.E. MainLayout import MainLayout.
     In MainLayout, separate functions are made for each panel.
Fri Dec 19 15:46:52 2003 UTC (16 years, 1 month ago) by hwang
Changes since 1.19: +2 -3 lines
Diff to previous 1.19 , to selected 1.18
	Catalogpanel.py
		added the double click
	MainLayout.py
		catalog_tree is not modifible
Thu Nov 13 21:41:08 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: SC-01, SC-02, sc-14Nov03-linux-01, sc-14Nov03-linux-02
Diff to previous 1.18
duplicate server error trapped
Revision 1.18 - (view) (download) (as text) (annotate) - [selected]
Thu Nov 13 19:21:46 2003 UTC (16 years, 2 months ago) by efrank
Diff to previous 1.17
back to localhost for init
Thu Nov 13 01:41:16 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: sc-12Nov03-linux-02
Changes since 1.16: +9 -2 lines
Diff to previous 1.16 , to selected 1.18
RecoElemPanel:
	fix a few bugs related to menu commands.  most related to problems
	not detecting special cases like "nothing selected" or "this node
	i9s special because its the root"
CatalogPanel:
	make the Seed part of the tree include a node, "Spontaneous Reactions"
	which olds all the spontaneous reactions in Seed (those without enzymes)
Wed Nov 12 22:56:33 2003 UTC (16 years, 2 months ago) by efrank
Changes since 1.15: +5 -0 lines
Diff to previous 1.15 , to selected 1.18
Lots of changes to start port to mac.  lots of fiddling with layout because
we are doing something wrong, and it shows up on Mac.
Also alot of work to make enzymes work, including EC.  focus is on seed.
Wed Nov 5 21:30:08 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: sc-06Nov03-linuxLeft-01, sc-12Nov03-linux-01
Changes since 1.14: +1 -0 lines
Diff to previous 1.14 , to selected 1.18
cursor busy was not being turned off in one case
Wed Nov 5 21:07:55 2003 UTC (16 years, 2 months ago) by efrank
Changes since 1.13: +89 -15 lines
Diff to previous 1.13 , to selected 1.18
Catalogpanel:
	Extend so that multiple Seed servers can be used.  A right click in the
	panel brings up a menu in which there is an "Add Server" entry.  Selecting
	that prompts for a server name.  that server is connected to, the org
	list is read, ettc., and all are put into the catalog.
Wed Nov 5 02:28:44 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: efrank-initialSeed-04Nov03, sc-works-00
Changes since 1.12: +17 -12 lines
Diff to previous 1.12 , to selected 1.18
Modifications to read data from Seed.  Now can read all the reactions/compounds
data associatd with a reconstrruction.  In ross' terms, we're reading out
the formal rconstruction.
Fri Oct 17 20:25:57 2003 UTC (16 years, 3 months ago) by efrank
Changes since 1.11: +43 -0 lines
Diff to previous 1.11 , to selected 1.18
Add catalog for reading from FIG/Seed
Requires updated FaST/
Thu Sep 25 23:48:06 2003 UTC (16 years, 3 months ago) by hwang
Changes since 1.10: +19 -0 lines
Diff to previous 1.10 , to selected 1.18
	Added enzyme buttons/text/grid
	Added exit button to allow user to exit normally
Mon Aug 18 15:55:57 2003 UTC (16 years, 5 months ago) by efrank
CVS Tags: V00-00-00, V00-00-01
Changes since 1.9: +11 -0 lines
Diff to previous 1.9 , to selected 1.18
Start documenting the code a trifle.  All files have been modified by adding
the list of def'd methods at the top of the class.  Must add description
strings, but this is a start.
Thu Aug 7 19:14:27 2003 UTC (16 years, 5 months ago) by efrank
Diff to previous 1.8 , to selected 1.18
Thu Aug 7 02:39:46 2003 UTC (16 years, 5 months ago) by efrank
Diff to previous 1.7 , to selected 1.18
adding to Metabolite panel so that we can search for metabolites.
main.py: move some init stuff out of main.py into associated panel.
mainlayout: clean up and reorg a bit.  lots of renames
rxpanel: commented out to speed up startup.
Mon Aug 4 16:18:47 2003 UTC (16 years, 5 months ago) by efrank
Changes since 1.6: +0 -5 lines
Diff to previous 1.6 , to selected 1.18
more tweaks for making things work.  no fundamental changes.  oh...except
in RecoElemPanel where we now use wxTreeCtrl EVT_TREE_SEL_CHANGED to figure
out when there's a hit on something.  Before, we were not picking up
selections on the top nodes.  That meant that a recoElem with no kids but
*with* reactions could not have its reactions listed.
Mon Aug 4 12:46:49 2003 UTC (16 years, 5 months ago) by efrank
Changes since 1.5: +52 -26 lines
Diff to previous 1.5 , to selected 1.18
sync with kaitlyn's mods.  add new fn'ality:
Catalogpanel.py:
   o include Wit as Datasource via FaST/WitFactory
   o Catalog tree of data sources expands to basic level at startup
   o to handle multiple data sources:
        We use EVT_TREE_SEL_CHANGED to know when a user has chosen something.
        At that point, we remember the data associated with tree item that was
        set when the item was added to the tree.  That data is a tuple comprising
        (ptr-to-function, arg list). When the load button is hit, it looks at
        this tuple and evaluates ptr-to-fnction on the arg list.  The idea is
        that when the catalog tree is built, it is built by various data-base
        specific functions.  Those functions know the database they are dealing
        with, so they can load the (func, args) correctly to achieve the correct
        behavior.  The point here is that wxPython only allows you set a single
        selection-handler per tree, not per tree item.  Thus we build our own
        little dispatch handler as just described since our tree is really
        heterogeneous.  Get it?
MainLayout.py:
   o Just some name changes, like the title of the window.
Fri Aug 1 20:53:06 2003 UTC (16 years, 5 months ago) by efrank
Changes since 1.4: +14 -7 lines
Diff to previous 1.4 , to selected 1.18
catalogPanel:
	change so that EVT_TREE_SEL_CHANGED rather than EVT_LEFT_DCLICK so that
	we work through tree as single click.
mainLayout:
	had to latch the Id fro the catalog_tree control
	changed text in some buttons and tabs
Fri Aug 1 18:54:31 2003 UTC (16 years, 5 months ago) by efrank
Changes since 1.3: +72 -12 lines
Diff to previous 1.3 , to selected 1.18
Catalogpanel:
	modify so that the catalog is a tree.  the top level nodes in the tree
	list the data factories, e.g., Bss, Wit, etc.
main.py
	to match above.
Fri Aug 1 15:33:39 2003 UTC (16 years, 5 months ago) by hwang
Changes since 1.2: +7 -4 lines
Diff to previous 1.2 , to selected 1.18
Thu Jul 31 15:54:29 2003 UTC (16 years, 5 months ago) by efrank
CVS Tags: efrank-worksBeforeCatalogTree
Changes since 1.1: +16 -10 lines
Diff to previous 1.1 , to selected 1.18
1) change so that when an item is selected, the load does not start right away.  instead,
   we just rcord which thing was selected.
2) wire in the LOAD button.  the load button handler does the recoelem load refered
   to in 1)
3) stifle some printouts
Mon Jul 28 22:31:13 2003 UTC (16 years, 5 months ago) by hwang
Diff to selected 1.18
