Log of /PyGUI/Catalogpanel.py
Parent Directory
Revision
1.35 -
view)
download)
as text)
annotate)
[select for diffs]
Tue Jul 13 21:15:07 2004 UTC (15 years, 5 months ago) by
efrank
Branch:
MAIN
CVS Tags:
forRick-14Jul04-0
Changes since
1.34: +4 -12 lines
Diff to
previous 1.34
to
selected 1.1
Schema:
o change size of Function column from 64 to 128.
More reasonable size and avoids a crash.
o RebuldDb...runs all the steps of rebuilding the database.
o biuldNewBssCatalog: go to new BssFactory ctor
CatalogServices:
o remove setFoundryId from DataFactoryBase. Now expect that info
to be in the DB itself and for ctor of derivative to set it.
FaST:
o Migrate to new DbManager from DBconnect. Includes moving to
new nextSeqVal().
o Now get fid from database
PyGui:
o Changed to follow mods above.
o
Revision
1.34 -
view)
download)
as text)
annotate)
[select for diffs]
Mon Jul 12 20:38:19 2004 UTC (15 years, 5 months ago) by
efrank
Branch:
MAIN
Changes since
1.33: +4 -11 lines
Diff to
previous 1.33
to
selected 1.1
KahOM/KahDataMgr:
first pass at top level data manager to be returned from catalogentry read
Schema:
added KahDatabaseInfo to put fid into database.
create- changed so that no long initialize name of top catalogEntry (see below)
destroyBss- changed !#/usr/bin/py to env py
FaST:
txMgr - fixed close()...added self
BssFactory - now gets fid via kahDatabaseInfo in database
PyGUI
change so that something or another
Revision
1.33 -
view)
download)
as text)
annotate)
[select for diffs]
Fri Jul 9 19:08:13 2004 UTC (15 years, 5 months ago) by
efrank
Branch:
MAIN
Changes since
1.32: +9 -7 lines
Diff to
previous 1.32
to
selected 1.1
Had a loop between catalogpanel putting a factory into the catalog
in loadCatalog() and the callback handler in MainLayout for added factories
trying to call into loadCatalog().
got rid of the adding of factories in loadCatalog().
now factory is added in very topmost level (ModelEditor). the callback
chain/observer takes care of the rest.
Revision
1.32 -
view)
download)
as text)
annotate)
[select for diffs]
Fri Jul 9 15:29:36 2004 UTC (15 years, 5 months ago) by
sheradon
Branch:
MAIN
Changes since
1.31: +4 -6 lines
Diff to
previous 1.31
to
selected 1.1
Catalogpanel.py
change catalog load so that a) turn off localhost seed b) stuff
i don't remember
MainLayout:
in callback for newDataFactory in catalog: remember to get catalog
loaded
MainMenuBar:
Revision
1.26 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Jun 9 22:36:10 2004 UTC (15 years, 6 months ago) by
efrank
Branch:
MAIN
CVS Tags:
V00-00-02,
forKubal-15Jun04
Changes since
1.25: +54 -46 lines
Diff to
previous 1.25
to
selected 1.1
o clean up double foundryId problem in FoundryItems
o change names in CatalogEntry to read() and write()
o write the write() method just mentioned
o get writing to work again, propagate changes into PyGUI
o add plugin capability to modelEditor
Revision
1.25 -
view)
download)
as text)
annotate)
[select for diffs]
Wed May 26 01:38:25 2004 UTC (15 years, 6 months ago) by
efrank
Branch:
MAIN
Changes since
1.24: +251 -28 lines
Diff to
previous 1.24
to
selected 1.1
Lots of work aimed at getting catalog services to work, incorporating
catalog editing into the model editor, and simplifying the api
for going form path to model in hand to work with.
CatalogEntryTop was changed to CatalogEntrBase and made base of CatalogEntry
rather than other way around to break a dependency loop that was causing
python import problems. CatalogEntry is still the base class to use
for extending to new data factories.
changed open() to return catalogEntry rather than foundryItemKey. simpler
for the user and more opportunity to encapsulate.
made catalogEntry able to read a recoElem and return it. all done in
terms of arch abstractions. this is temorary. we will add a Navigator
or Manager class and that will be returned from the CatalogEntry rather
than recoElem. that's becausee Recoelem is just one of many things
that will be present, e.g., conditions data.
PyGui/MainMenuBar. split out to help stay sane for when that becomes
more complex.
Moved add seed server to menu bar so that right click in catalog panel
coudl be used to pull up catalog editing tools.
Revision
1.24 -
view)
download)
as text)
annotate)
[select for diffs]
Fri Mar 26 17:12:46 2004 UTC (15 years, 8 months ago) by
efrank
Branch:
MAIN
Changes since
1.23: +11 -10 lines
Diff to
previous 1.23
to
selected 1.1
Modifications to install the new Catalog code, FoundryId stuff. I ripped
out old code as well: the list of foundryComboBoxes is gone since we now
have just one combo box.
the notion of FoundryId's intVal is gone. at least for the moment. it's too hard
at the mment to have a (bottleneck!) central authority to manage the intVals.
so, starting now, foundryId's are based on strings that are notionally URLs and
its up to the dataFoundry manager to make sure all distinct instances at his
site have distinct urls.
this also means that if a foundry moves, then the history information that
refers to it becomes incorrect.
Revision
1.22 -
view)
download)
as text)
annotate)
[select for diffs]
Fri Mar 5 19:30:38 2004 UTC (15 years, 9 months ago) by
hwang
Branch:
MAIN
Changes since
1.21: +3 -32 lines
Diff to
previous 1.21
to
selected 1.1
Catalogpanel.py
Got rid of the "Load to Navigator" button
FontManager.py
fixed variable consistancy
MainLayout.py
Added combobox label and got rid of "Load to Navigator" button
Revision
1.21 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Feb 25 17:08:17 2004 UTC (15 years, 9 months ago) by
hwang
Branch:
MAIN
Changes since
1.20: +5 -4 lines
Diff to
previous 1.20
to
selected 1.1
Changed all the files so that the past inconsistancies of variable and classes names
are consistant. I.E. MainLayout import MainLayout.
In MainLayout, separate functions are made for each panel.
Revision
1.17 -
view)
download)
as text)
annotate)
[select for diffs]
Thu Nov 13 01:41:16 2003 UTC (16 years, 1 month ago) by
efrank
Branch:
MAIN
CVS Tags:
sc-12Nov03-linux-02
Changes since
1.16: +9 -2 lines
Diff to
previous 1.16
to
selected 1.1
RecoElemPanel:
fix a few bugs related to menu commands. most related to problems
not detecting special cases like "nothing selected" or "this node
i9s special because its the root"
CatalogPanel:
make the Seed part of the tree include a node, "Spontaneous Reactions"
which olds all the spontaneous reactions in Seed (those without enzymes)
Revision
1.16 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Nov 12 22:56:33 2003 UTC (16 years, 1 month ago) by
efrank
Branch:
MAIN
Changes since
1.15: +5 -0 lines
Diff to
previous 1.15
to
selected 1.1
Lots of changes to start port to mac. lots of fiddling with layout because
we are doing something wrong, and it shows up on Mac.
Also alot of work to make enzymes work, including EC. focus is on seed.
Revision
1.14 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Nov 5 21:07:55 2003 UTC (16 years, 1 month ago) by
efrank
Branch:
MAIN
Changes since
1.13: +89 -15 lines
Diff to
previous 1.13
to
selected 1.1
Catalogpanel:
Extend so that multiple Seed servers can be used. A right click in the
panel brings up a menu in which there is an "Add Server" entry. Selecting
that prompts for a server name. that server is connected to, the org
list is read, ettc., and all are put into the catalog.
Revision
1.8 -
view)
download)
as text)
annotate)
[select for diffs]
Thu Aug 7 02:39:46 2003 UTC (16 years, 4 months ago) by
efrank
Branch:
MAIN
Changes since
1.7: +1 -1 lines
Diff to
previous 1.7
to
selected 1.1
adding to Metabolite panel so that we can search for metabolites.
main.py: move some init stuff out of main.py into associated panel.
mainlayout: clean up and reorg a bit. lots of renames
rxpanel: commented out to speed up startup.
Revision
1.7 -
view)
download)
as text)
annotate)
[select for diffs]
Mon Aug 4 16:18:47 2003 UTC (16 years, 4 months ago) by
efrank
Branch:
MAIN
Changes since
1.6: +0 -5 lines
Diff to
previous 1.6
to
selected 1.1
more tweaks for making things work. no fundamental changes. oh...except
in RecoElemPanel where we now use wxTreeCtrl EVT_TREE_SEL_CHANGED to figure
out when there's a hit on something. Before, we were not picking up
selections on the top nodes. That meant that a recoElem with no kids but
*with* reactions could not have its reactions listed.
Revision
1.6 -
view)
download)
as text)
annotate)
[select for diffs]
Mon Aug 4 12:46:49 2003 UTC (16 years, 4 months ago) by
efrank
Branch:
MAIN
Changes since
1.5: +52 -26 lines
Diff to
previous 1.5
to
selected 1.1
sync with kaitlyn's mods. add new fn'ality:
Catalogpanel.py:
o include Wit as Datasource via FaST/WitFactory
o Catalog tree of data sources expands to basic level at startup
o to handle multiple data sources:
We use EVT_TREE_SEL_CHANGED to know when a user has chosen something.
At that point, we remember the data associated with tree item that was
set when the item was added to the tree. That data is a tuple comprising
(ptr-to-function, arg list). When the load button is hit, it looks at
this tuple and evaluates ptr-to-fnction on the arg list. The idea is
that when the catalog tree is built, it is built by various data-base
specific functions. Those functions know the database they are dealing
with, so they can load the (func, args) correctly to achieve the correct
behavior. The point here is that wxPython only allows you set a single
selection-handler per tree, not per tree item. Thus we build our own
little dispatch handler as just described since our tree is really
heterogeneous. Get it?
MainLayout.py:
o Just some name changes, like the title of the window.
Revision
1.5 -
view)
download)
as text)
annotate)
[select for diffs]
Fri Aug 1 20:53:06 2003 UTC (16 years, 4 months ago) by
efrank
Branch:
MAIN
Changes since
1.4: +14 -7 lines
Diff to
previous 1.4
to
selected 1.1
catalogPanel:
change so that EVT_TREE_SEL_CHANGED rather than EVT_LEFT_DCLICK so that
we work through tree as single click.
mainLayout:
had to latch the Id fro the catalog_tree control
changed text in some buttons and tabs
Revision
1.4 -
view)
download)
as text)
annotate)
[select for diffs]
Fri Aug 1 18:54:31 2003 UTC (16 years, 4 months ago) by
efrank
Branch:
MAIN
Changes since
1.3: +72 -12 lines
Diff to
previous 1.3
to
selected 1.1
Catalogpanel:
modify so that the catalog is a tree. the top level nodes in the tree
list the data factories, e.g., Bss, Wit, etc.
main.py
to match above.
Revision
1.2 -
view)
download)
as text)
annotate)
[select for diffs]
Thu Jul 31 15:54:29 2003 UTC (16 years, 4 months ago) by
efrank
Branch:
MAIN
CVS Tags:
efrank-worksBeforeCatalogTree
Changes since
1.1: +16 -10 lines
Diff to
previous 1.1
1) change so that when an item is selected, the load does not start right away. instead,
we just rcord which thing was selected.
2) wire in the LOAD button. the load button handler does the recoelem load refered
to in 1)
3) stifle some printouts
Revision
1.1 -
view)
download)
as text)
annotate)
[selected]
Mon Jul 28 22:31:13 2003 UTC (16 years, 4 months ago) by
hwang
Branch:
MAIN
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
