[Bio] / PyGUI / AGGetPubDialog.py Repository:
Log of /PyGUI/AGGetPubDialog.py
Links to mass-spec-01: (view) (download) (as text) (annotate)
Wed Jul 14 20:22:13 2004 UTC (15 years, 6 months ago) by efrank
CVS Tags: HEAD, MigrateToNewPackage, V00-00-03, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, mass-spec-03
Changes since 1.4: +10 -3 lines
getting it to work.  in a rush for rick demo.
Mon Jul 12 17:12:43 2004 UTC (15 years, 6 months ago) by ctreatma
Changes since 1.3: +3 -6 lines
Use 2-element dialog to get host/port.
Remove some test code.
Fri Jul 9 20:01:50 2004 UTC (15 years, 6 months ago) by ctreatma
Changes since 1.2: +27 -20 lines
	Fixed checkbox issues, converted dialog box design to comply with ModelEditor design standards.
Thu Jul 8 14:56:17 2004 UTC (15 years, 6 months ago) by ctreatma
Changes since 1.1: +53 -6 lines
	Removed test code from MainMenuBar.py, implemented popup dialog for connecting to servers published on the AG. (Charles)
Tue Jul 6 19:53:10 2004 UTC (15 years, 6 months ago) by hwang
Diff to selected 1.4
	MainMenuBar
	  put in the AGGetPubDialog for Charles
	AGGetPubDialog
	  grid information popup
