[Bio] / PRAST / WebPage / UploadPlasmid.pm Repository:
Log of /PRAST/WebPage/UploadPlasmid.pm
Wed May 20 14:47:53 2009 UTC (10 years, 6 months ago) by arodri7
CVS Tags: HEAD
Changes since 1.9: +29 -4 lines
upload page asks more from the user
Wed May 20 14:10:57 2009 UTC (10 years, 6 months ago) by arodri7
Changes since 1.8: +51 -30 lines
Wed Apr 8 16:23:30 2009 UTC (10 years, 7 months ago) by arodri7
added the keep_gene_call option
Thu Apr 2 18:24:50 2009 UTC (10 years, 8 months ago) by arodri7
commented out certain boxes that don't apply to plasmids for now
Thu Apr 2 18:17:22 2009 UTC (10 years, 8 months ago) by arodri7
Changes since 1.5: +75 -54 lines
Mon Mar 30 20:10:01 2009 UTC (10 years, 8 months ago) by arodri7
Changes since 1.4: +12 -3 lines
deny genetic code 4
Wed Mar 4 20:19:21 2009 UTC (10 years, 9 months ago) by jared
changes made
Wed Mar 4 20:16:32 2009 UTC (10 years, 9 months ago) by jared
Changes since 1.2: +4 -4 lines
changes made
Wed Mar 4 17:26:49 2009 UTC (10 years, 9 months ago) by jared
switching rast to prast
Wed Mar 4 15:37:38 2009 UTC (10 years, 9 months ago) by jared
Branch: Initial
CVS Tags: start
Diff to previous 1.1 , to next main 1.10
Initial version
Branch point for: Initial
