[Bio] / PRAST / WebPage / JobDetails.pm Repository:
View of /PRAST/WebPage/JobDetails.pm
Sun Mar 15 16:14:07 2009 UTC (10 years, 8 months ago) by arodri7
CVS Tags: HEAD
added the right pages to PRAST
package PRAST::WebPage::JobDetails;
use strict;
use warnings;
use POSIX;
use base qw( WebPage );
use WebConfig;
1;
=pod
=head1 NAME
JobDetails - an instance of WebPage which displays detailed information about a job
=head1 DESCRIPTION
Job Details page
=head1 METHODS
=over 4
=item * B<init> ()
Called when the web page is instanciated.
=cut
sub init {
  my $self = shift;
  $self->title("Jobs Details");
  # sanity check on job
  my $id = $self->application->cgi->param('job') || '';
  my $job;
  eval { $job = $self->app->data_handle('RAST')->Job->init({ id => $id }); };
  if ($job) {
    # redirect to details page for that type
    if ($job->type eq 'Genome') {
      $self->application->redirect('Genome');
    elsif ($job->type eq 'Metagenome') {
      $self->application->redirect('Metagenome');
    else {
      $self->application->error('Unknown job type. Unable to display JobDetails for it.');
  else {
    $self->app->error("Unable to retrieve the job '$id'.");
  $self->data('job', $job);
=pod
=item * B<get_image_and_text_for_status> (I<status>, I<stage_name>)
Returns the an image filename and text message which describe the I<status> entry.
=cut
sub get_image_and_text_for_status {
  my ($self, $status, $stage) = @_;
  $status = $status || 'not_started';
  unless ($status and $stage) {
    die "Incomplete parameters.\n";
  if ($status eq 'not_started') {
    return ( IMAGES."rast-not_started.png", "$stage has not yet started.");
  elsif ($status eq 'queued') {
    return ( IMAGES."rast-queued.png", "$stage is queued for computation.");
  elsif ($status eq 'in_progress') {
    return ( IMAGES."rast-in_progress.png", "$stage is currently in progress.");
  elsif ($status eq 'complete') {
    return ( IMAGES."rast-complete.png", "$stage has been successfully completed.");
  elsif ($status eq 'error') {
    return ( IMAGES."rast-error.png", "$stage has returned an error.");
  elsif ($status eq 'requires_intervention') {
    return ( IMAGES."rast-error.png", "$stage needs user input!");
  else {
    die "Found unknown status '$status'.\n";
=pod
=item * B<get_section_bar>(I<status>, I<stage_name>)
Returns the html for a Details page section bar, displaying the name of
stage I<stage> and the status I<status>
=cut
sub get_section_bar {
  my ($img, $text) = $self->get_image_and_text_for_status($status, $stage);
  return "<p id='section_bar'><img src='$img'>$text</p>";
=pod
=item * B<required_rights>()
Returns a reference to the array of required rights
=cut
sub required_rights {
  my $rights = [ [ 'login' ], ];
  push @$rights, [ 'edit', 'genome', $_[0]->data('job')->genome_id ]
    if ($_[0]->data('job'));
  return $rights;
