[Bio] / PPO / ppo_sqlite_copy.pl Repository:
View of /PPO/ppo_sqlite_copy.pl
Wed Dec 5 19:05:53 2007 UTC (12 years, 6 months ago) by paarmann
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, mobedac_release_05302012, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, rast_rel_2008_06_16, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
Makefile copies perl scripts to the common bin dir, renamed perl scripts to avoid name clashes
#!/usr/bin/env perl
use strict;
use warnings;
use PPOBackend;
# usage message
sub usage {
  my $error = shift;
  print "Usage: ppo_sqlite_copy.pl source_database target_database\n";
  print "Error: $error\n" if($error);
  exit;
my $source = $ARGV[0] | '';
-f $source || &usage("Unable to find database source '$source'.");
my $target = $ARGV[1] || &usage('No new database name given');
!-f $target || &usage("Target file already exists.");
my $connect = "DBI:SQLite:dbname=$target";
system("cp", $source, $target) == 0
  || &usage("Unable to copy database from $source to $target.");
my $backend = PPOBackend->new(-backend => 'SQLite', -database => $source);
if (ref $backend) {
  $backend->update_row('_references',
		       { '_database' => $target,
			 '_backend_data' => $connect },
		       '_database='.$backend->dbh->quote($source))
    || die "Failed to update database.";
else {
  &usage("Unable to open database '$source'.");
$backend->dbh->disconnect;
exit 1;
