[Bio] / PPO / PPOBackend.pm Repository:
Log of /PPO/PPOBackend.pm
Fri Apr 2 07:49:00 2010 UTC (9 years, 7 months ago) by paczian
CVS Tags: myrast_33, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
fixed line switch that broke PPO
Tue Mar 23 13:57:51 2010 UTC (9 years, 8 months ago) by paczian
Changes since 1.10: +12 -7 lines
added object cache exclusion
Thu Jul 16 13:13:40 2009 UTC (10 years, 4 months ago) by paczian
CVS Tags: rast_rel_2009_0925, rast_rel_2010_0118
Changes since 1.9: +2 -1 lines
added socket option
Tue Nov 11 14:09:13 2008 UTC (11 years ago) by paczian
CVS Tags: rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09
Changes since 1.8: +32 -1 lines
added function to support mass resolving of objects
Fri May 9 01:32:59 2008 UTC (11 years, 6 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
Added a trace message.
Tue Apr 29 20:12:11 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.6: +30 -23 lines
Added SQL tracing.
Thu Apr 10 14:44:41 2008 UTC (11 years, 7 months ago) by paarmann
CVS Tags: rast_rel_2008_04_23
Changes since 1.5: +1 -4 lines
Sun Mar 23 15:58:57 2008 UTC (11 years, 8 months ago) by parrello
Added tracing.
Thu Dec 13 21:26:18 2007 UTC (11 years, 11 months ago) by paarmann
Changes since 1.3: +100 -4 lines
added batch mode (crude, but functional)
Wed Aug 1 14:10:45 2007 UTC (12 years, 3 months ago) by paarmann
Changes since 1.2: +45 -47 lines
removed debugging code
Tue Jun 19 21:26:47 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.1: +47 -46 lines
Added tracing support.
Tue Jun 5 16:22:30 2007 UTC (12 years, 5 months ago) by paarmann
new version of the PPO
