[Bio] / PPO / DBObject.pm Repository:
Log of /PPO/DBObject.pm
Tue Mar 23 10:15:36 2010 UTC (9 years, 7 months ago) by paczian
CVS Tags: myrast_33, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.22: +50 -5 lines
Diff to previous 1.22
added no_object_cache option
added objects_for_ids
Mon Jul 20 14:06:37 2009 UTC (10 years, 3 months ago) by paczian
CVS Tags: rast_rel_2009_0925, rast_rel_2010_0118
Changes since 1.21: +2 -2 lines
Diff to previous 1.21
error message for non found referenced objects has been clarified to give detailed debug information
Tue Nov 11 14:03:21 2008 UTC (11 years ago) by paczian
CVS Tags: rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09
Changes since 1.20: +83 -1 lines
Diff to previous 1.20
added resolve method to efficiently resolve arrays of object references
Tue Apr 29 20:10:59 2008 UTC (11 years, 6 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
Changes since 1.19: +25 -24 lines
Diff to previous 1.19
Switched from die to Confess.
Mon Feb 25 17:55:30 2008 UTC (11 years, 8 months ago) by paarmann
CVS Tags: rast_rel_2008_04_23
Changes since 1.18: +4 -4 lines
Diff to previous 1.18
Tue Feb 5 04:43:08 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.17: +4 -3 lines
Diff to previous 1.17
Added tracing.
Fri Aug 10 15:58:59 2007 UTC (12 years, 3 months ago) by paczian
Changes since 1.16: +6 -2 lines
Diff to previous 1.16
no clue what i did
Tue Jun 5 16:22:30 2007 UTC (12 years, 5 months ago) by paarmann
Changes since 1.15: +205 -263 lines
new version of the PPO
Thu May 17 16:14:07 2007 UTC (12 years, 5 months ago) by paczian
CVS Tags: Release-20070601
Changes since 1.14: +7 -5 lines
hotfix for passing undefined values when retrieving an object by init
Fri Apr 27 16:54:59 2007 UTC (12 years, 6 months ago) by paczian
Wed Feb 28 16:42:32 2007 UTC (12 years, 8 months ago) by paarmann
Changes since 1.12: +2 -2 lines
Wed Feb 28 16:34:45 2007 UTC (12 years, 8 months ago) by paarmann
more typos
Wed Feb 28 16:33:41 2007 UTC (12 years, 8 months ago) by paarmann
Changes since 1.10: +7 -7 lines
follow up fix
Wed Feb 28 16:31:02 2007 UTC (12 years, 8 months ago) by paarmann
Changes since 1.9: +7 -1 lines
fixed cache query logic
Wed Feb 7 22:30:36 2007 UTC (12 years, 9 months ago) by paczian
Changes since 1.8: +83 -74 lines
performance upgrade for object retrieval
Wed Jan 31 22:10:11 2007 UTC (12 years, 9 months ago) by paarmann
Changes since 1.7: +38 -19 lines
added support for default attribute values
Wed Jan 31 20:25:38 2007 UTC (12 years, 9 months ago) by paarmann
Changes since 1.6: +14 -7 lines
removed previous fix and did it the right way
fixed bug where empty array where returned as undef
Wed Jan 31 17:48:26 2007 UTC (12 years, 9 months ago) by paarmann
Changes since 1.5: +5 -4 lines
added array check to is_index
Tue Jan 30 21:17:51 2007 UTC (12 years, 9 months ago) by paarmann
Changes since 1.4: +100 -136 lines
added tied arrays (DBSQLArray)
added object cache
Mon Dec 4 20:11:35 2006 UTC (12 years, 11 months ago) by paarmann
fixed a bug calling attribute method with undef as value
Fri Dec 1 20:35:25 2006 UTC (12 years, 11 months ago) by paczian
Changes since 1.2: +70 -2 lines
added init method and changed get_objects to always return an array
Thu Nov 16 15:27:23 2006 UTC (12 years, 11 months ago) by paarmann
Changes since 1.1: +26 -16 lines
Mon Nov 13 20:31:50 2006 UTC (13 years ago) by paarmann
moved from GenDBDatabase
