[Bio] / ModelEditorGlade / arch_spec_Glade.mk Repository:
Log of /ModelEditorGlade/arch_spec_Glade.mk
Default branch: MigrateToNewPackage
Mon Oct 4 19:52:17 2004 UTC (15 years, 1 month ago) by efrank
Branch: MAIN, MigrateToNewPackage
CVS Tags: HEAD, v0
Migrating package name.  Used to be ModelEditor.  I want to use ModelEditor
name for what used to be PyGUI.  So
	o check out head of ModelEditor
	o tag it MigrateToNewPackage
	o import it as ModelEditorGlade
	o remove all files from ModelEditor
	o add everything from PyGUI
Branch point for: MAIN, MigrateToNewPackage
