[Bio] / ModelEditorGlade / .nfs0007c88200000008 Repository:
Log of /ModelEditorGlade/.nfs0007c88200000008
Default branch: MigrateToNewPackage
Mon Oct 4 19:52:17 2004 UTC (15 years, 2 months ago) by efrank
Branch: MAIN, MigrateToNewPackage
CVS Tags: HEAD, v0
Migrating package name.  Used to be ModelEditor.  I want to use ModelEditor
name for what used to be PyGUI.  So
	o check out head of ModelEditor
	o tag it MigrateToNewPackage
	o import it as ModelEditorGlade
	o remove all files from ModelEditor
	o add everything from PyGUI
Branch point for: MAIN, MigrateToNewPackage
