[Bio] / ModelEditor / pluginExample.py Repository:
Log of /ModelEditor/pluginExample.py
Fri Mar 11 21:33:13 2005 UTC (14 years, 6 months ago) by efrank
CVS Tags: HEAD, before-dynamics-persistence, lwc, preTreatmanDyn, treatman-lastDay-0
Changes since 1.4: +5 -48 lines
1. introduce Model as king of the hill rather than RecoElem.
2. migrations to follow
3. new modules for by-peg filtering
4. first stab at externalized app fwk
5. moved seed data factory
bunch of timing code still in this ...need to take out
Fri Jan 7 14:40:33 2005 UTC (14 years, 8 months ago) by efrank
CVS Tags: post-st-migration, post-st-migration2, pre-wxPython-2515-migration
migration to new schematools generated classes.
new chemdb.
factor chem out of seed data factory
imporved configuration of modeleditor
Tue Nov 9 14:24:47 2004 UTC (14 years, 10 months ago) by efrank
CVS Tags: sc04-finalDay
set def seed server name.  hwire for sc.
funny businesse in gathreRx
Thu Oct 21 01:14:39 2004 UTC (14 years, 11 months ago) by efrank
CVS Tags: sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
Changes since 1.1: +35 -5 lines
now dumps stoich mat too
Mon Oct 4 20:02:45 2004 UTC (14 years, 11 months ago) by efrank
CVS Tags: PostMigrationFromPyGUI
Sucked out of PyGUI, tag MigrateToNewPackage.
hasta la vista, PyGUI
