[Bio] / ModelEditor / RXpanel.py Repository:
Log of /ModelEditor/RXpanel.py
Fri Mar 11 21:33:13 2005 UTC (14 years, 6 months ago) by efrank
CVS Tags: HEAD, before-dynamics-persistence, lwc, preTreatmanDyn, treatman-lastDay-0
Changes since 1.8: +6 -9 lines
1. introduce Model as king of the hill rather than RecoElem.
2. migrations to follow
3. new modules for by-peg filtering
4. first stab at externalized app fwk
5. moved seed data factory
bunch of timing code still in this ...need to take out
Fri Jan 7 14:40:33 2005 UTC (14 years, 8 months ago) by efrank
CVS Tags: post-st-migration, post-st-migration2, pre-wxPython-2515-migration
Changes since 1.7: +27 -15 lines
migration to new schematools generated classes.
new chemdb.
factor chem out of seed data factory
imporved configuration of modeleditor
Fri Nov 19 23:22:49 2004 UTC (14 years, 10 months ago) by efrank
migrate FoundryId to FoundryInfo.
rewrite base object model classes in KahOM and FoundryId to use SchemaTools
   for their data nuggets.
code runs package level test for these two packages successfully.
everything else is now broken.....
we'r ready for the migration.
Thu Nov 4 02:19:59 2004 UTC (14 years, 10 months ago) by efrank
CVS Tags: sc04-finalDay, sc2004-3, sc2004-4
cleanAGEntry:		removes stale state from sharedApp
DDL related: 		increased size of varchars for names of chemistry stuff
			to handle big fat seed stuff
SeedDataFactory		turn off mapping of assignments to chemistry.
KahCatAGCfgMgr		remmoveKey() to support cleanAGEntry
StringReaction:		allow multiple : in strings being parsed to handle
			junk from seed with lots of colons.  ONly the final
			is treated as deliminting the end of the enzyme name
ModelEditor		signal handling, but commentd back out.
RXpanel			duh
Tue Nov 2 22:15:50 2004 UTC (14 years, 10 months ago) by efrank
Changes since 1.4: +3 -1 lines
more evt_combobox cleanup
Tue Nov 2 21:35:10 2004 UTC (14 years, 10 months ago) by efrank
Changes since 1.3: +9 -14 lines
fixing EVT_COMBOBOX vs EVT_TEXT
Tue Nov 2 20:50:17 2004 UTC (14 years, 10 months ago) by efrank
Changes since 1.2: +12 -0 lines
rxpanel some debug prints.
recoElemPanel:  add ability to merge a copy onto a branch
Tue Oct 5 15:19:52 2004 UTC (14 years, 11 months ago) by efrank
CVS Tags: sc2004-0, sc2004-1, sc2004-2
Changes since 1.1: +6 -6 lines
wonderif this will conflict with a file in attic???
Mon Oct 4 20:02:45 2004 UTC (14 years, 11 months ago) by efrank
CVS Tags: PostMigrationFromPyGUI
Sucked out of PyGUI, tag MigrateToNewPackage.
hasta la vista, PyGUI
