[Bio] / ModelEditor / RXOnAddPageDialog.py Repository:
Log of /ModelEditor/RXOnAddPageDialog.py
Fri Mar 11 21:33:13 2005 UTC (13 years, 10 months ago) by efrank
CVS Tags: HEAD, before-dynamics-persistence, lwc, preTreatmanDyn, treatman-lastDay-0
Changes since 1.6: +19 -13 lines
1. introduce Model as king of the hill rather than RecoElem.
2. migrations to follow
3. new modules for by-peg filtering
4. first stab at externalized app fwk
5. moved seed data factory
bunch of timing code still in this ...need to take out
Thu Feb 24 16:33:23 2005 UTC (13 years, 10 months ago) by mkubal
Changes since 1.5: +24 -9 lines
editable stoich
Tue Feb 8 21:05:52 2005 UTC (13 years, 11 months ago) by efrank
correctly use specie name for adding rx
Mon Jan 31 16:52:09 2005 UTC (13 years, 11 months ago) by efrank
Changes since 1.3: +3 -3 lines
migration to wxPy 2.5.1.5.  basic function on mac now ok.
Fri Jan 7 14:40:33 2005 UTC (14 years ago) by efrank
CVS Tags: post-st-migration, post-st-migration2, pre-wxPython-2515-migration
Changes since 1.2: +6 -0 lines
migration to new schematools generated classes.
new chemdb.
factor chem out of seed data factory
imporved configuration of modeleditor
Tue Oct 5 15:19:52 2004 UTC (14 years, 3 months ago) by efrank
CVS Tags: sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
wonderif this will conflict with a file in attic???
Mon Oct 4 20:02:45 2004 UTC (14 years, 3 months ago) by efrank
CVS Tags: PostMigrationFromPyGUI
Sucked out of PyGUI, tag MigrateToNewPackage.
hasta la vista, PyGUI
