[Bio] / ModelEditor / RXFromMetPageDialog.py Repository:
Log of /ModelEditor/RXFromMetPageDialog.py
Links to post-st-migration: (view) (download) (as text) (annotate)
Fri Jan 7 14:40:33 2005 UTC (15 years, 1 month ago) by efrank
CVS Tags: post-st-migration, post-st-migration2, pre-wxPython-2515-migration
Changes since 1.2: +7 -7 lines
migration to new schematools generated classes.
new chemdb.
factor chem out of seed data factory
imporved configuration of modeleditor
Tue Oct 5 15:19:52 2004 UTC (15 years, 4 months ago) by efrank
CVS Tags: sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
wonderif this will conflict with a file in attic???
Mon Oct 4 20:02:45 2004 UTC (15 years, 4 months ago) by efrank
CVS Tags: PostMigrationFromPyGUI
Sucked out of PyGUI, tag MigrateToNewPackage.
hasta la vista, PyGUI
