[Bio] / ModelEditor / ModelEditorExe.py Repository:
Log of /ModelEditor/ModelEditorExe.py
Fri Mar 11 21:33:13 2005 UTC (14 years, 5 months ago) by efrank
CVS Tags: HEAD, before-dynamics-persistence, lwc, preTreatmanDyn, treatman-lastDay-0
1. introduce Model as king of the hill rather than RecoElem.
2. migrations to follow
3. new modules for by-peg filtering
4. first stab at externalized app fwk
5. moved seed data factory
bunch of timing code still in this ...need to take out
