[Bio] / ModelEditor / ModelEditor Repository:
Log of /ModelEditor/ModelEditor
Fri Apr 22 15:14:03 2005 UTC (14 years, 4 months ago) by efrank
CVS Tags: HEAD, before-dynamics-persistence, lwc, preTreatmanDyn, treatman-lastDay-0
Changes since 1.10: +23 -2 lines
Diff to previous 1.10 , to selected 1.6
change ModelEditor (launcher script) to sniff for mac_wx_workaround and,
if found, use it to diddle PYPATH so that can run under Seed environment
where there's both bobThon and sys pyThon
Fri Mar 11 21:33:13 2005 UTC (14 years, 5 months ago) by efrank
Changes since 1.9: +8 -165 lines
Diff to previous 1.9 , to selected 1.6
1. introduce Model as king of the hill rather than RecoElem.
2. migrations to follow
3. new modules for by-peg filtering
4. first stab at externalized app fwk
5. moved seed data factory
bunch of timing code still in this ...need to take out
Tue Feb 1 16:06:14 2005 UTC (14 years, 6 months ago) by efrank
Changes since 1.8: +3 -2 lines
LoadFromLigand now takes connect string of db to load into.
KahDbAdmin now handles SEQEUENCE disparaty in DDL, ora vs postgres.
ModelEditor-more fixes for 2.5.1.5.
	now set selection after call to plugin
	other stuff too
Mon Jan 31 16:52:09 2005 UTC (14 years, 6 months ago) by efrank
Changes since 1.7: +5 -3 lines
migration to wxPy 2.5.1.5.  basic function on mac now ok.
Fri Jan 7 14:40:33 2005 UTC (14 years, 7 months ago) by efrank
CVS Tags: post-st-migration, post-st-migration2, pre-wxPython-2515-migration
Changes since 1.6: +74 -7 lines
migration to new schematools generated classes.
new chemdb.
factor chem out of seed data factory
imporved configuration of modeleditor
Revision 1.6 - (view) (download) (annotate) - [selected]
Fri Nov 19 23:22:49 2004 UTC (14 years, 9 months ago) by efrank
migrate FoundryId to FoundryInfo.
rewrite base object model classes in KahOM and FoundryId to use SchemaTools
   for their data nuggets.
code runs package level test for these two packages successfully.
everything else is now broken.....
we'r ready for the migration.
Mon Nov 8 00:34:17 2004 UTC (14 years, 9 months ago) by efrank
CVS Tags: sc04-finalDay, sc2004-4
Changes since 1.4: +2 -1 lines
bssdfwrite:   don't set inerror and just skip things that cause problems in
write.  this will be moot when go to new schema.  some keggg/seed things
are just wierd
bunch of stuff:  centralize default AG venue for kah venue
seedDataFactory:  trap messed up rxns from seed.
                  exclude from reaction list.
Thu Nov 4 02:19:59 2004 UTC (14 years, 9 months ago) by efrank
CVS Tags: sc2004-3
Changes since 1.3: +26 -0 lines
cleanAGEntry:		removes stale state from sharedApp
DDL related: 		increased size of varchars for names of chemistry stuff
			to handle big fat seed stuff
SeedDataFactory		turn off mapping of assignments to chemistry.
KahCatAGCfgMgr		remmoveKey() to support cleanAGEntry
StringReaction:		allow multiple : in strings being parsed to handle
			junk from seed with lots of colons.  ONly the final
			is treated as deliminting the end of the enzyme name
ModelEditor		signal handling, but commentd back out.
RXpanel			duh
Tue Nov 2 17:48:26 2004 UTC (14 years, 9 months ago) by efrank
Changes since 1.2: +4 -1 lines
eggbeater
Fri Oct 22 02:54:03 2004 UTC (14 years, 10 months ago) by efrank
CVS Tags: sc2004-0, sc2004-1, sc2004-2
MeAGMgr:'
	derivative of KahCatAGCfgMgr extended to handle messaging needed
	for shared editing
KahOM:
	deep copies of object model (in part)
ModelEditor:
	add shared editing over AG
Tue Oct 5 15:19:52 2004 UTC (14 years, 10 months ago) by efrank
Diff to selected 1.6
wonderif this will conflict with a file in attic???
