[Bio] / ModelEditor / ModelEditor.html Repository:
Log of /ModelEditor/ModelEditor.html
Fri Mar 11 21:33:13 2005 UTC (14 years, 3 months ago) by efrank
CVS Tags: HEAD, before-dynamics-persistence, lwc, preTreatmanDyn, treatman-lastDay-0
Changes since 1.1: +11 -0 lines
1. introduce Model as king of the hill rather than RecoElem.
2. migrations to follow
3. new modules for by-peg filtering
4. first stab at externalized app fwk
5. moved seed data factory
bunch of timing code still in this ...need to take out
Mon Oct 4 20:02:45 2004 UTC (14 years, 8 months ago) by efrank
CVS Tags: PostMigrationFromPyGUI, post-st-migration, post-st-migration2, pre-wxPython-2515-migration, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
Sucked out of PyGUI, tag MigrateToNewPackage.
hasta la vista, PyGUI
