[Bio] / ModelEditor / ModelEditor.cfg Repository:
Log of /ModelEditor/ModelEditor.cfg
Fri Apr 22 15:14:03 2005 UTC (14 years, 4 months ago) by efrank
CVS Tags: HEAD, before-dynamics-persistence, lwc, preTreatmanDyn, treatman-lastDay-0
change ModelEditor (launcher script) to sniff for mac_wx_workaround and,
if found, use it to diddle PYPATH so that can run under Seed environment
where there's both bobThon and sys pyThon
Mon Jan 31 16:52:09 2005 UTC (14 years, 6 months ago) by efrank
migration to wxPy 2.5.1.5.  basic function on mac now ok.
Fri Jan 7 14:42:14 2005 UTC (14 years, 7 months ago) by efrank
CVS Tags: post-st-migration, post-st-migration2, pre-wxPython-2515-migration
config file sample.
