[Bio] / ModelEditor / MetabolitePanel.py Repository:
Log of /ModelEditor/MetabolitePanel.py
Links to post-st-migration: (view) (download) (as text) (annotate)
Fri Jan 7 14:40:33 2005 UTC (15 years, 1 month ago) by efrank
CVS Tags: post-st-migration, post-st-migration2, pre-wxPython-2515-migration
Changes since 1.4: +47 -3 lines
migration to new schematools generated classes.
new chemdb.
factor chem out of seed data factory
imporved configuration of modeleditor
Mon Nov 1 16:50:35 2004 UTC (15 years, 3 months ago) by efrank
CVS Tags: sc04-finalDay, sc2004-1, sc2004-2, sc2004-3, sc2004-4
Changes since 1.3: +7 -15 lines
more ripping otu short
Mon Nov 1 16:41:43 2004 UTC (15 years, 3 months ago) by efrank
CVS Tags: sc2004-0
removing Short name concept from metabs
fixed layout problem from orphaned WIT stuff
Tue Oct 5 15:19:52 2004 UTC (15 years, 4 months ago) by efrank
wonderif this will conflict with a file in attic???
Mon Oct 4 20:02:45 2004 UTC (15 years, 4 months ago) by efrank
CVS Tags: PostMigrationFromPyGUI
Sucked out of PyGUI, tag MigrateToNewPackage.
hasta la vista, PyGUI
