[Bio] / ModelEditor / MetabolitePanel.py Repository:
Log of /ModelEditor/MetabolitePanel.py
Fri Mar 11 21:33:13 2005 UTC (14 years, 5 months ago) by efrank
CVS Tags: HEAD, before-dynamics-persistence, lwc, preTreatmanDyn, treatman-lastDay-0
Changes since 1.7: +10 -7 lines
1. introduce Model as king of the hill rather than RecoElem.
2. migrations to follow
3. new modules for by-peg filtering
4. first stab at externalized app fwk
5. moved seed data factory
bunch of timing code still in this ...need to take out
Tue Feb 8 20:06:56 2005 UTC (14 years, 6 months ago) by efrank
Changes since 1.6: +4 -0 lines
improve info shown in table after new metab aded
Tue Feb 8 16:51:29 2005 UTC (14 years, 6 months ago) by efrank
Changes since 1.5: +35 -28 lines
move exporter to Cytoscape out to its own module.
get the isClass attrib up into the model editor for viewing/setting.
Fri Jan 7 14:40:33 2005 UTC (14 years, 7 months ago) by efrank
CVS Tags: post-st-migration, post-st-migration2, pre-wxPython-2515-migration
Changes since 1.4: +47 -3 lines
migration to new schematools generated classes.
new chemdb.
factor chem out of seed data factory
imporved configuration of modeleditor
Mon Nov 1 16:50:35 2004 UTC (14 years, 9 months ago) by efrank
CVS Tags: sc04-finalDay, sc2004-1, sc2004-2, sc2004-3, sc2004-4
Changes since 1.3: +7 -15 lines
more ripping otu short
Mon Nov 1 16:41:43 2004 UTC (14 years, 9 months ago) by efrank
CVS Tags: sc2004-0
removing Short name concept from metabs
fixed layout problem from orphaned WIT stuff
Tue Oct 5 15:19:52 2004 UTC (14 years, 10 months ago) by efrank
wonderif this will conflict with a file in attic???
Mon Oct 4 20:02:45 2004 UTC (14 years, 10 months ago) by efrank
CVS Tags: PostMigrationFromPyGUI
Sucked out of PyGUI, tag MigrateToNewPackage.
hasta la vista, PyGUI
