[Bio] / ModelEditor / MeSharedEditServer.py Repository:
Log of /ModelEditor/MeSharedEditServer.py
Links to treatman-lastDay-0: (view) (download) (as text) (annotate)
Fri Jan 7 14:40:33 2005 UTC (14 years, 6 months ago) by efrank
CVS Tags: post-st-migration, post-st-migration2, pre-wxPython-2515-migration, preTreatmanDyn, treatman-lastDay-0
migration to new schematools generated classes.
new chemdb.
factor chem out of seed data factory
imporved configuration of modeleditor
Thu Nov 11 20:59:45 2004 UTC (14 years, 8 months ago) by efrank
CVS Tags: sc04-finalDay
Changes since 1.1: +6 -6 lines
changes from the floor at SC.  wonder what they were...
Sat Oct 23 18:55:47 2004 UTC (14 years, 8 months ago) by efrank
CVS Tags: sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
get shared editing going at basic level.
