[Bio] / ModelEditor / MeSharedEditServer.py Repository:
Log of /ModelEditor/MeSharedEditServer.py
Links to before-dynamics-persistence: (view) (download) (as text) (annotate)
Sun Dec 4 17:20:34 2005 UTC (13 years, 4 months ago) by efrank
CVS Tags: HEAD, before-dynamics-persistence, lwc
Changes since 1.3: +9 -4 lines
1. migrate from deprecated xmlrpcconverter to PrimitiveConverter.  This
makes shared editing by AG work again.  Also, now trivial to add arbitrary
object networks to Model and still ship  between kah instances.  maybe.
2. fix up dynamics stuff.  dunno how charl's stuff ever worked, but it did.
then it didn't.  now it does again.  migrate to classFromPath and rationalize
a bunch of stuff.
Fri Jan 7 14:40:33 2005 UTC (14 years, 3 months ago) by efrank
CVS Tags: post-st-migration, post-st-migration2, pre-wxPython-2515-migration, preTreatmanDyn, treatman-lastDay-0
migration to new schematools generated classes.
new chemdb.
factor chem out of seed data factory
imporved configuration of modeleditor
Thu Nov 11 20:59:45 2004 UTC (14 years, 5 months ago) by efrank
CVS Tags: sc04-finalDay
Changes since 1.1: +6 -6 lines
changes from the floor at SC.  wonder what they were...
Sat Oct 23 18:55:47 2004 UTC (14 years, 6 months ago) by efrank
CVS Tags: sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
get shared editing going at basic level.
