[Bio] / ModelEditor / MeAGMgr.py Repository:
Log of /ModelEditor/MeAGMgr.py
Tue Nov 2 17:48:26 2004 UTC (14 years, 9 months ago) by efrank
CVS Tags: HEAD, before-dynamics-persistence, lwc, post-st-migration, post-st-migration2, pre-wxPython-2515-migration, preTreatmanDyn, sc04-finalDay, sc2004-3, sc2004-4, treatman-lastDay-0
Changes since 1.2: +34 -2 lines
eggbeater
Sat Oct 23 18:55:47 2004 UTC (14 years, 10 months ago) by efrank
CVS Tags: sc2004-0, sc2004-1, sc2004-2
Changes since 1.1: +34 -11 lines
get shared editing going at basic level.
Fri Oct 22 02:54:03 2004 UTC (14 years, 10 months ago) by efrank
MeAGMgr:'
	derivative of KahCatAGCfgMgr extended to handle messaging needed
	for shared editing
KahOM:
	deep copies of object model (in part)
ModelEditor:
	add shared editing over AG
