[Bio] / ModelEditor / Makefile Repository:
Log of /ModelEditor/Makefile
Fri Mar 11 21:33:13 2005 UTC (14 years, 3 months ago) by efrank
CVS Tags: HEAD, before-dynamics-persistence, lwc, preTreatmanDyn, treatman-lastDay-0
1. introduce Model as king of the hill rather than RecoElem.
2. migrations to follow
3. new modules for by-peg filtering
4. first stab at externalized app fwk
5. moved seed data factory
bunch of timing code still in this ...need to take out
Tue Oct 5 15:19:52 2004 UTC (14 years, 8 months ago) by efrank
CVS Tags: post-st-migration, post-st-migration2, pre-wxPython-2515-migration, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
Changes since 1.3: +2 -1 lines
wonderif this will conflict with a file in attic???
Mon Oct 4 20:02:45 2004 UTC (14 years, 8 months ago) by efrank
CVS Tags: PostMigrationFromPyGUI
Changes since 1.2: +8 -227 lines
Sucked out of PyGUI, tag MigrateToNewPackage.
hasta la vista, PyGUI
Mon Jul 7 17:50:30 2003 UTC (15 years, 11 months ago) by efrank
CVS Tags: MigrateToNewPackage
ModelEditorImpl.cc:
	split out SBW stuff into RecoElemSBW package so it can be reused.
Makefile:
	dependncy on RecoElemSBW moved later in link list.
interface.c
 	changed string printed on first realization of text box.
Thu Jun 26 22:42:34 2003 UTC (16 years ago) by hwang
Branch point for: initial
