[Bio] / ModelEditor / MainMenuBar.py Repository:
Log of /ModelEditor/MainMenuBar.py
Tue Jan 17 17:12:47 2006 UTC (13 years, 7 months ago) by efrank
CVS Tags: HEAD, lwc
persistence for dynamics stuff
bunch of flux modelinig stuff including flux model building in modeleditor
Sun Dec 4 17:20:34 2005 UTC (13 years, 8 months ago) by efrank
CVS Tags: before-dynamics-persistence
1. migrate from deprecated xmlrpcconverter to PrimitiveConverter.  This
makes shared editing by AG work again.  Also, now trivial to add arbitrary
object networks to Model and still ship  between kah instances.  maybe.
2. fix up dynamics stuff.  dunno how charl's stuff ever worked, but it did.
then it didn't.  now it does again.  migrate to classFromPath and rationalize
a bunch of stuff.
Fri Mar 11 21:33:13 2005 UTC (14 years, 5 months ago) by efrank
CVS Tags: preTreatmanDyn, treatman-lastDay-0
Changes since 1.9: +12 -7 lines
1. introduce Model as king of the hill rather than RecoElem.
2. migrations to follow
3. new modules for by-peg filtering
4. first stab at externalized app fwk
5. moved seed data factory
bunch of timing code still in this ...need to take out
Mon Jan 31 16:52:09 2005 UTC (14 years, 6 months ago) by efrank
Changes since 1.8: +7 -2 lines
migration to wxPy 2.5.1.5.  basic function on mac now ok.
Fri Jan 7 14:40:33 2005 UTC (14 years, 7 months ago) by efrank
CVS Tags: post-st-migration, post-st-migration2, pre-wxPython-2515-migration
Changes since 1.7: +107 -19 lines
migration to new schematools generated classes.
new chemdb.
factor chem out of seed data factory
imporved configuration of modeleditor
Tue Nov 9 14:24:47 2004 UTC (14 years, 9 months ago) by efrank
CVS Tags: sc04-finalDay
Changes since 1.6: +1 -0 lines
set def seed server name.  hwire for sc.
funny businesse in gathreRx
Mon Nov 8 00:34:17 2004 UTC (14 years, 9 months ago) by efrank
CVS Tags: sc2004-4
Changes since 1.5: +7 -0 lines
bssdfwrite:   don't set inerror and just skip things that cause problems in
write.  this will be moot when go to new schema.  some keggg/seed things
are just wierd
bunch of stuff:  centralize default AG venue for kah venue
seedDataFactory:  trap messed up rxns from seed.
                  exclude from reaction list.
Tue Nov 2 17:48:26 2004 UTC (14 years, 9 months ago) by efrank
CVS Tags: sc2004-3
Changes since 1.4: +42 -39 lines
eggbeater
Sat Oct 23 18:55:47 2004 UTC (14 years, 10 months ago) by efrank
CVS Tags: sc2004-0, sc2004-1, sc2004-2
Changes since 1.3: +0 -2 lines
get shared editing going at basic level.
Fri Oct 22 02:54:03 2004 UTC (14 years, 10 months ago) by efrank
Changes since 1.2: +87 -9 lines
MeAGMgr:'
	derivative of KahCatAGCfgMgr extended to handle messaging needed
	for shared editing
KahOM:
	deep copies of object model (in part)
ModelEditor:
	add shared editing over AG
Tue Oct 5 15:19:52 2004 UTC (14 years, 10 months ago) by efrank
wonderif this will conflict with a file in attic???
Mon Oct 4 20:02:45 2004 UTC (14 years, 10 months ago) by efrank
CVS Tags: PostMigrationFromPyGUI
Sucked out of PyGUI, tag MigrateToNewPackage.
hasta la vista, PyGUI
