[Bio] / ModelEditor / MainLayout.py Repository:
Log of /ModelEditor/MainLayout.py
Links to post-st-migration: (view) (download) (as text) (annotate)
Fri Jan 7 14:40:33 2005 UTC (15 years, 1 month ago) by efrank
CVS Tags: post-st-migration, post-st-migration2, pre-wxPython-2515-migration
Changes since 1.5: +3 -2 lines
migration to new schematools generated classes.
new chemdb.
factor chem out of seed data factory
imporved configuration of modeleditor
Tue Nov 2 22:15:50 2004 UTC (15 years, 3 months ago) by efrank
CVS Tags: sc04-finalDay, sc2004-3, sc2004-4
more evt_combobox cleanup
Tue Nov 2 17:48:26 2004 UTC (15 years, 3 months ago) by efrank
eggbeater
Mon Nov 1 16:50:35 2004 UTC (15 years, 3 months ago) by efrank
CVS Tags: sc2004-1, sc2004-2
Changes since 1.2: +6 -10 lines
more ripping otu short
Mon Nov 1 16:41:43 2004 UTC (15 years, 3 months ago) by efrank
CVS Tags: sc2004-0
Changes since 1.1: +29 -41 lines
removing Short name concept from metabs
fixed layout problem from orphaned WIT stuff
Mon Oct 4 20:02:45 2004 UTC (15 years, 4 months ago) by efrank
CVS Tags: PostMigrationFromPyGUI
Sucked out of PyGUI, tag MigrateToNewPackage.
hasta la vista, PyGUI
