[Bio] / ModelEditor / AGGetPubDialog.py Repository:
Log of /ModelEditor/AGGetPubDialog.py
Mon Jan 31 16:52:09 2005 UTC (14 years, 7 months ago) by efrank
CVS Tags: HEAD, before-dynamics-persistence, lwc, preTreatmanDyn, treatman-lastDay-0
migration to wxPy 2.5.1.5.  basic function on mac now ok.
Mon Nov 8 00:34:17 2004 UTC (14 years, 10 months ago) by efrank
CVS Tags: post-st-migration, post-st-migration2, pre-wxPython-2515-migration, sc04-finalDay, sc2004-4
Changes since 1.5: +0 -3 lines
bssdfwrite:   don't set inerror and just skip things that cause problems in
write.  this will be moot when go to new schema.  some keggg/seed things
are just wierd
bunch of stuff:  centralize default AG venue for kah venue
seedDataFactory:  trap messed up rxns from seed.
                  exclude from reaction list.
Mon Nov 1 17:39:08 2004 UTC (14 years, 10 months ago) by efrank
CVS Tags: sc2004-2, sc2004-3
Changes since 1.4: +17 -7 lines
obfuscate connect info.
Mon Nov 1 17:09:46 2004 UTC (14 years, 10 months ago) by efrank
fixes for int
Fri Oct 29 16:15:53 2004 UTC (14 years, 10 months ago) by efrank
CVS Tags: sc2004-0, sc2004-1
Changes since 1.2: +11 -7 lines
add ability to put either proxy or descriptor for direct conn
also, trap error for funky rx formats
Thu Oct 28 16:17:18 2004 UTC (14 years, 10 months ago) by efrank
Changes since 1.1: +23 -17 lines
break a bunch of stuff.
sync before porta-video is packed
Mon Oct 4 20:02:45 2004 UTC (14 years, 11 months ago) by efrank
CVS Tags: PostMigrationFromPyGUI
Sucked out of PyGUI, tag MigrateToNewPackage.
hasta la vista, PyGUI
