[Bio] / ModelEditor / .deps / callbacks.P Repository:
Log of /ModelEditor/.deps/callbacks.P
Default branch: initial
Links to V00-00-00: (view) (download) (as text) (annotate)
Thu Jun 26 22:42:34 2003 UTC (16 years, 4 months ago) by hwang
Branch: MAIN, initial
CVS Tags: HEAD, MigrateToNewPackage, PostMigrationFromPyGUI, V00-00-00, before-dynamics-persistence, lwc, post-st-migration, post-st-migration2, pre-wxPython-2515-migration, preTreatmanDyn, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4, treatman-lastDay-0
First version of a package to edit models.  Uses Glade to do Gui layout.
We are finding that we are doing more and more by hand rather than with
glade, especially since the implementation of the event handlers is in
C++.
Branch point for: MAIN, initial
